Any of you seen this on the 3D nav screen?
By ecpiii · Jul 01, 2009in General💬 5 posts👁️ 1,077 views
Posted Jul 01, 2009 · 18:43 UTC#1
I posted this in the troubleshooting forum, but I wanted to be sure it was seen. 2D is perfect, but 3D looks pretty f'd up above what seems to be a horizon line. Any ideas??
Posted Jul 01, 2009 · 19:51 UTC#2
use the smart zoom and the tilt, just play with it, also, check the teraain detail settings
Posted Jul 01, 2009 · 20:37 UTC#3
Cool, I will try that. Is there no sky above the horizon like there was in the z1 z2?? That's what has been throwing me off. I have the terrain set on high detail Probably just stick to 2d.
Posted Jul 01, 2009 · 20:55 UTC#4
if you get the tilt settings right you'll see the sky, also, you might want to turn your smart zoom off
Posted Jul 02, 2009 · 03:09 UTC#5
Mine has done that from day one using the stock map. If you go into the smrat zoom settings.. you can change the zoom out a bit closer.... I use one bump from all the way out.... the bar will still show 0.2 but it will be a bit closer on the map.
