Bluetooth Active Indicator
By mr_cs · Jul 02, 2009in Hacks/Mods💬 8 posts👁️ 1,521 views
Posted Jul 02, 2009 · 14:13 UTC#1
Does anybody know how to put on the screen an indication that bluetooth is active?
On occasions my phone does not connect, and I do not realise until I receive a call or try to make one.
Colin
Posted Jul 02, 2009 · 14:29 UTC#2
Mine has a blue light on the front panel that lights up when the phone is connected, F900BT, what model do you have ?
Posted Jul 02, 2009 · 14:30 UTC#3
Colin
You should have a blue light indicator right by the sd card slot. We wouldnt need one on the map screen.
Posted Jul 02, 2009 · 15:11 UTC#4
yeah same i've got the F900BT and it has a little blue light next to the SD slot that flashes when connected
Posted Jul 02, 2009 · 15:12 UTC#5
Thanks for the prompt responses. Maybe my blue light is dim, but I will look for it.
Colin
Posted Jul 02, 2009 · 16:12 UTC#6
My blue light next to the SD slots lights up all the time when its paired and connected. have you tried to re-pair your phone to the unit? There should be no reason that intermittently it does not connect unless its not in range or the bluetooth is turned off on the phone.
Posted Aug 10, 2009 · 20:12 UTC#7
Colin
here's something that i just found now, try this code, just add your personal BMP file and put it in your navigatemap_800_480.ui
Posted Aug 11, 2009 · 08:00 UTC#8
Thanks, I will try this.
Colin
