So my XM sounds slight worse then FM and not nearly as good as CD on my D1. I also drop signal occasionally when I go behind a building or through trees. My antenna is underneath the plastic under my windshield wipers, but has no metal on it.
Anyway, has anyone else noticed the XM sound being sub par even with a good signal? Is there a way to check signal strength? Anything else to check?
Posted Oct 31, 2006 · 21:00 UTC#1
