Need help with color code of OEM radio and speaker wiring diagram for 2009 Camry Hybrid. Thank U.
2009 Toyota Camry Hybrid wiring
Radio 12V blue/yellow + radio, white 10 pin plug, pin 4
On 8 speaker systems, it is in the white 20 pin plug, pin 1.
Radio Ground brown - radio, white 10 pin plug, pin 7
On 8 speaker systems, it is in the white 20 pin plug, pin 20.
Radio Ignition gray + radio, white 10 pin plug, pin 3
On 8 speaker systems, it is in the white 20 pin plug, pin 11.
Radio Illumination green (parking lights); white/black (dimmer) +,- radio, white 10 pin plug, pin 10; white 6 pin plug, pin 5
On 8 speaker systems, they are in the white 20 pin plug, pins 2 and 12.
Factory Amp Turn-on N/A
Power Antenna orange + radio, white 10 pin plug, pin 8
On 8 speaker systems, it is in the white 20 pin plug, pin 13.
Left Front Speaker (+/-) pink - purple +,- radio, white 10 pin plug, pins 2 and 6
If equipped, the amplifier is under the passenger seat. On vehicles with amplifier, the speaker wires are pink - purple at the amplifier, white 12 pin plug, pins 2 and 1. The tweeter wires are pink - purple at the amplifier, blue 10 pin plug, pins 8 and 7.
Right Front Speaker (+/-) lt. green - blue +,- radio, white 10 pin plug, pins 1 and 5
If equipped, the amplifier is under the passenger seat. On vehicles with amplifier, the speaker wires are lt. green - blue at the amplifier, white 12 pin plug, pins 9 and 3. The tweeter wires are lt. green - blue at the amplifier, blue 10 pin plug, pins 2 and 6.
Left Rear Speaker (+/-) black - yellow +,- radio, white 6 pin plug, pins 2 and 6
If equipped, the amplifier is under the passenger seat. On vehicles with amplifier, the rear speakers are bi-amplified. The high end wires are black - yellow at the amplifier, blue 10 pin plug, pins 3 and 9. The low end wires are green/white - brown at the amplifier, white 12 pin plug, pins 4 and 10.
Right Rear Speaker (+/-) red - white +,- radio, white 6 pin plug, pins 1 and 3
If equipped, the amplifier is under the passenger seat. On vehicles with amplifier, the rear speakers are bi-amplified. The high end wires are red - white at the amplifier, blue 10 pin plug, pins 10 and 4. The low end wires are blue - yellow at the amplifier, white 12 pin plug, pins 5 and 12.
