2009 VW GTI Stock Sirius Integration without IP BUS
By firemedic4 · Jul 07, 2009in Hacks/Mods💬 6 posts👁️ 1,382 views
Posted Jul 07, 2009 · 19:29 UTC#1
My question is...is it possible?
I've heard of people using a splitter of sorts. For reference, I have a 2009 MKV VW GTI and a Pioneer F90BT. The GTI has an integrated dual purpose powered antenna and have two wires coming from in the dash; one for the antenna and one for the Sirius. I have been told there are two ways to do this; either by the IP BUS and Sirius antenna seperately or you could somehow use the 'splitter' and combine. Anyone have any thoughts or ideas?
Posted Jul 07, 2009 · 20:04 UTC#2
This would be interesting, but I don't see how not using the IP Bus would work. That takes the Sirius signal and converts all for the radio. I would think without this that you would not be able to use the Sirius display and have to use the Aux input at that point. Will be interesting to see how this would work
Posted Jul 08, 2009 · 17:33 UTC#3
i have a 2007 gti - i just purchased the pioneer xm unit, unplugged the antenna from the stock sat unit, removed the sheathing (the piece of plastic over the connection), plugged it into the pioneer sat unit and that was it - xm in my car
Posted Jul 10, 2009 · 19:16 UTC#4
interesting. thanks for info! I'll try that this weekend.
Posted Jul 11, 2009 · 18:23 UTC#5
By the way, the two antenna leads that are plugged into the back of the stock stereo on your GTI are both for your AM/FM, not for satellite. VW radios use a diversity receiver, which utilizes two antennas that are both located in your rear window. If you have OEM satellite radio, the antenna for it is in the sharkfin antenna on the roof. The Sirius module is located under a plastic cover under the passenger seat. It has one antenna lead going into it, which you can use for the Pioneer XM or Sirius modules. As has already been stated, just take the plastic Fakra connector housing off of it and it will plug right into the Pioneer module.
Posted Jul 11, 2009 · 20:47 UTC#6
what about for a 09 for escape? I want to still use the oem roof antena with a portable sirius player and later get the module for th F900bt. Can i still use the oem factory antenna?
