f700 problems.
By ludrof · Jul 08, 2009in Hacks/Mods💬 9 posts👁️ 1,298 views
Posted Jul 08, 2009 · 15:51 UTC#1
hello, i went to instal the newest version for the f700; 2.6 or whatever it is, and it did it just fine. when i got done with the update, i hit the reset for 5 secondsjust like it tells you to. know when the system loads, the start up in process screen stays there. if i click on av source, it goes away, but i cant listen to music or anything because i can not click on the settings button;then when i go back to the main menu, its there. also , i can not use my map because i can not click the ok button on the warning screen. did i do something wrong, or is there something wrong with the update? i tried to reload it, but nothing happens.
Posted Jul 08, 2009 · 16:19 UTC#2
If you haven't tried already,try point 2 listed in step 4 from below to see if that gets you in.
Step 4
After your system has rebooted itself, press and hold down the system "reset" button (which is
located just to the left of the "eject" button) for five (5) seconds and release it.
Next, determine which of the following applies:
1. If the system boots ups and displays the main menu, go to Step 6.
2. If the system does not display the main menu AND the screen is blacked out, press and hold
the reset button and the eject button at the same time for five seconds and then release them.
The system should reboot automatically and display the main menu. Now proceed to Step 6.
FYI - I haven't updated mine, just trying to extend a helping hand to you.
Posted Jul 08, 2009 · 18:53 UTC#3
I'm having the exact same issue. None of the listed steps fix the issue. :oops:
Posted Jul 08, 2009 · 20:52 UTC#4
I didn't hit the reset button when I did mine and it works good. You may want to redownload the file and reload the update on your unit. Did you happen to make a backup before you did it?
Posted Jul 08, 2009 · 21:03 UTC#5
no, i did not make a backup, and i have tried all of the reset options. i called pioneer and i have tried everything they have told me to try. i tried redownloading the update, but the system does not register it and just boots up like it normally doe, but then just does the same thing where you cant do anything
Posted Jul 08, 2009 · 21:24 UTC#6
What is Pioneer going to do for you?
Posted Jul 08, 2009 · 21:37 UTC#7
all the guy said is you will have to send it in to get serviced
Posted Jul 08, 2009 · 21:41 UTC#8
I'm currently trying to un-screw mine. I got the new testmode (2.3) to load. I swiped the drive, then reloaded the update. No joy. I'm going to try to reload the 2.0 firmware and do a full restore. I'll let you know how it goes.
Posted Jul 09, 2009 · 12:55 UTC#9
I was able to get mine back to 2.0.
I used the latest test mode file (2.3) to get back into it, then loaded the full back-up that TK421 uploaded last night.
Testmode 2.3: download/file.php?id=7376
Full back-up:
ftp://www.turboss.com
Username: avicuser
Password: Avic411
