Grounding wires for bypass
By dkoon2007 · Jul 09, 2009in Hacks/Mods💬 3 posts👁️ 1,362 views
Posted Jul 09, 2009 · 23:14 UTC#1
Whats the best way to ground the two wires?
#1 wire....disconnect from the e-bake switch and run the wire to a bolt or screw?
#2 wire...Relocate a wire and then connect it to the unit's ground wire via a connector?
This stuff is basic to some of you folks but I have very little experience with automotive electrics.
Are there better ways?
Thanks in advance
Posted Jul 09, 2009 · 23:45 UTC#2
Here is the easiest.
Wire #1 and #2 just connect them both to the black ground wire on the rear of the Z. All 3 of these wires will be attached to the vehicle ground.
Posted Jul 09, 2009 · 23:48 UTC#3
Oh, thank you for the reply....makes sense.
