Need help finding VSS on a 2007 ESCAPE
By 2005yellowhorse · Jul 12, 2009in Vehicle Specific Wiring💬 3 posts👁️ 1,387 views
Posted Jul 12, 2009 · 02:08 UTC#1
Hello,
I have searched all over the internet for this question but can anyone help me find the VSS Cable that I can use to connect my Avic-90bt on my 2007 Ford Escape Limited. If possible pictures would help. I'm not as savvy as most of you more experienced installers out there. Any help would be greatly appreciated. :(
Thanks in Advance,
Anthony
Posted Jul 16, 2009 · 21:49 UTC#2
Gray / Black wire located at the ABS Brake Control Module the ABS Module is located at the drivers side of the firewall -wheel well area . NOTE on the Hybrid models the ABS module is at the passengers side of the of the engine compartment.
Posted Jul 24, 2009 · 16:18 UTC#3
Speed Sense gray/black ac ABS or brake system control module
The ABS control module is on the rear driver side of the engine compartment. On the Hybrid models, the brake system control module is on the rear passenger side of the engine compartment. On vehicles with the 6-disc in-dash CD changer, this wire is also found in the radio harness.
