F500BT PROBLEM WITH LEET LAUNCHER
By shanawaz · Jul 13, 2009in Hacks/Mods💬 2 posts👁️ 1,257 views
Posted Jul 13, 2009 · 10:01 UTC#1
Hi. I just purchased the F500BT and got the NDG500 Amp and I pod cable with it.
After reading through the posts (ONLY POSTING CAUSE I CANT FIND ANY ANSWERS SO FAR) i realize that there is an issues that is unique to the F500BT.
Also the audio won't go through the external amp, it only goes out the little speaker in the back when using Leet Launcher.
I havent installed leet Launcher myself but before i do i would like to you ask you.
1. Does the ipod work if i install leet launcher?
2. Does Voice Control work on ipod to change songs?
3. Does Bluetooth work? and Voice Control for making calls?
4. Is it simple to switch between ipod n map just it is on the original OS?
5. Does the music stay on if you switch to map while listenning to ipod?
Also would like to ask the people who have had this problem about the audio only going through the speaker in the back...when does this happen...if i am listening to ipod through leetlauncher will i get sound only from the back speaker...like when does this happen...only while using leetlaunder and with which applications like blutooth, ipod, navigation?
One last questions:
Do you think it is totally worth installin this application on the f500bt?
Thanks for all your help.
Posted Jul 13, 2009 · 19:31 UTC#2
NM: I got leetlauncher to load. But I dont know how to get the Igo8 and tomtom maps ect.. to load up?
