I need to know if there is a way to just power up and down an N1 head unit to make sure that the screen goes in and out without having to wire the whole thing into the car radio wiring harness. Anyone have any suggestions?
Can I get power to the head unit without complete wiring?
Connect the positive and grounds?
To what? Are you saying just pull out the harness behind my radio and tap into the red and black wires? If so, that's what i'm trying not to have to do. Can I connect it to an old cell charger that is 12v with the red and ground wires?
If I connect only the positive and ground wire do I have to hook up the brain also. I only want to make sure the new flex cable works. Thanks in advance for any help.
Ahh ok.. I thought you meant without wiring the entire harness. Wiring just the positive and negative wires wouldn't take too long (just use some of these twisty things) http://www.wiringproducts.com/contents/ ... tlined.jpg. That way, it's easily reversible just for testing.
Other than that, I'm not sure. Sorry.
You can hook up just the battery power(yellow), accessory power(red) and ground(black) wires to check your unit. You WILL have to have the brain plugged in, also. The unit will NOT power up without it...
