Loading Custom POI's? with leet and IGO8
By lotust · Jul 15, 2009in Hacks/Mods💬 3 posts👁️ 923 views
Posted Jul 15, 2009 · 00:35 UTC#1
\iGo8\CONTENT\userdata? does not exsist. Can I just create the folder and add my .kml files?
Posted Jul 15, 2009 · 00:59 UTC#2
I'm slightly confused, I thought the iGo saved area was here:
My Flash Disk\USER\UserData\iGo
but maybe there is a different user area under the base iGo dir...
EDIT:
btw - could be wrong - I'm still learning this, but:
See the sys.txt in the leet iGo dir:
[folders]
data="\My Flash Disk\User\UserData\iGo"
Posted Jul 15, 2009 · 01:12 UTC#3
Im confused too. I just want to make the IGO8 see my Saved POIs I use to use with the regular Poineer software. im pretty sure you convert them with this http://poi.ashus.net/ to a .upoi format but I dont know if you put them on the SD card or on the flash disk?
thanks for looking.
