I will be completing my installation hopefully this weekend and wanted to go over two things:
1. I'll be using the Scosche HY05 Car Stereo Wiring Harness, can I assume based on what the wiring harness says is the correct wire. The reason I bring this up is because the wires inside the car have completely different colors then that of the HY05 wire harness. when connected.
2. When grounding, is it okay to connect the chasis ground with the parking brake and bypass wire all together? Or should they all be grounded separately?
Thanks for any feedback.
Posted Nov 03, 2006 · 17:24 UTC#1
