F Series power off/reboot while car is on.
By kernicn · Jul 16, 2009in General💬 20 posts👁️ 3,312 views
Posted Jul 16, 2009 · 01:38 UTC#1
I was wondering if there is a way to turn off a f700bt (not by turning the car off obv.)
Also, is there a way to do a hard reboot without turning the car off and on??
I did do a forum search before asking this question....
Thanks in advance.
Posted Jul 16, 2009 · 03:55 UTC#2
Thanks in advance.
No turn off. TO reboot, hit the reset button.
Posted Jul 16, 2009 · 04:10 UTC#3
You can turn it off, take a knife and cut the cables...
Boris, he never said he wanted to turn it back on... :lol:
Posted Jul 16, 2009 · 23:22 UTC#4
I second that notion. I think it is very stupid design for not being able to simply turn off the unit by pressing a knob or a button when you need it. It would be great if anyone can come up with the idea on how to turn this unit off and on when needed.
Posted Jul 17, 2009 · 02:35 UTC#5
why would you want to turn it off, turn off the screen if you dont want to see anythin...
Posted Jul 20, 2009 · 19:48 UTC#6
sometimes the only way I can get the ipod to connect after a failed connection is to reboot the unit. Currently I do this by turning the car off and then clutch starting it while going down the road. It would be nice to just press a button.
Posted Jul 20, 2009 · 19:57 UTC#7
It should be possible to add a button to the Navi screen that would call some illegal code, causing iGO to crash, which will reboot the headunit...
Posted Jul 21, 2009 · 01:04 UTC#8
I always just take the stylus and push the little reset button by the eject. Takes half a second then you wait for reboot, a whole lot eh, safer then turning off your vehicle while cruising, can't believe you do that, seriously.
Other then that there is an off button in the lower right corner on the select audio source screen. All this does is make the audio mute and the screen says off in th elower left corner.
Why would you need a physical off button? I think the point is due to the long boot up time to keep it always on. If it really bothers you you can always put in some kind of a acc cut off switch. You hit the on off switch, physical off. Super cheap at numerous stores etc.
Posted Jul 21, 2009 · 12:43 UTC#9
About the only other option would be to put a switch in the power lead that you could turn on and off.
Posted Jul 31, 2009 · 21:32 UTC#10
Hey Guys, you can always add a toggle switch or whatever kind of switch you want to the ground wire, break the connection, power off, switch back, power on!
Posted Aug 02, 2009 · 04:19 UTC#11
I had to add a toggle switch to mine. It freezes up every ounce in awhile and needs to be rebooted. I got sick and tired of having to pull over and turn my truck off and then back on, a real pain in the ass. Just cut the accessory wire and run it through a toggle switch, problem solved.
Posted Aug 02, 2009 · 07:05 UTC#12
I have a very small push-button switch mounted on my dash. Thats wired into a relay that is wired to the switched 12v on the avic(red wire) If it locks up i push the button and release it and its the same as turning the key off then back on. works great for when the bt hangs on me.
Posted Aug 05, 2009 · 03:20 UTC#13
Real quick question on this topic. I want to do the same thing, and picked up a momentary switch from radio shack. The switch is rated at 12v 50mA. Anyone know if the 50mA rating is too low to run the Accessory wire through?
I know the answer is to check the Amps on the wire, but i thought i would risk the abuse here in hopes of finding out BEFORE open the dash. :)
Any help is appreciated.
- dan
Posted Aug 05, 2009 · 04:26 UTC#14
- dan
Is it a Normally open or Normally closed Momentary Switch? because that will determine what way you will have to wire it up... and depending on how you wire it up the Amperage will not matter.
Aftermarket momentary switches in the automotive industry are generally Normally open... which means that the circuit is connected when the switch is pressed in and there is no connection at rest.
Posted Aug 05, 2009 · 13:44 UTC#15
Thanks, for the quick reply. To correct my previous post, it is a tactile switch, so I am beginning to think it is not the right switch for the job. I'd say normally closed, but let me describe the switch config, since it allows for either way.
There are four prongs, A, B, C, D. When in normal position, A and B are closed. When depressed, A and B are open, A and D are closed (not sure about B and C, didn't check cause at that point I stopped checking). So my intention is to connect the power leads to A and B. If the unit hangs, press the switch to cut the connection (hold down if needed), then release to allow for reboot.
I was going to attach the other ends of the leads to male and female plug in connectors (have no idea what they are called) to allow the switch to be easily disconnected. (Switch A prong connected to wire, connected to male plug, Switch B prong connected to wire and female plug, and the Acc wire will have a male and female plug).
My concern (or question) with the switch and the plugs is that since power will be constant through these, what is the risk of overheating? I know 50mA is very low, and admittedly (and obviously) I have NO experience with this stuff (but I can solder!!). :)
Thanks for the input.
- dan
Posted Aug 05, 2009 · 14:42 UTC#16
Thanks in advance.
In one of the menus there is an "OFF" button. Press it and it turns off.
Posted Aug 05, 2009 · 15:54 UTC#17
Really?
Posted Aug 05, 2009 · 23:09 UTC#18
Really?
No it does not turn it off it just turns the screen off... but the unit is still alive and fully functional.
Posted Aug 06, 2009 · 01:35 UTC#19
- dan
Yes 50mA is very low... I am not sure what the draw is on the screen but if you want to set up a fairly simple way to shut off the power to the accy on the head unit you can use a momentary (spring loaded push button) switch and a SPDT relay to do your interrupt. Here is how...
On the relay there will be terminals labeled 30, 85, 86, 87, and 87a. Take the Accy output from the vehicle and connect it to the 86 and 87a. Then take the 30 and connect that to the Accy input to the headunit. Leave the 87 not connected to anything but make sure that you insulate that terminal so it cannot touch anything. And the final connection is where you would take the 85 and connect that to the one side of the momentary switch then the other side of the switch you will wire to ground. BAM every time you press in the momentary switch it will interrupt the accy wire and shut off the radio just like turning off the key of the car, and it will keep that wire disconnected the entire time you hold that switch in, by using this method you can restart your screen without loosing any of your programmed settings. On average a standard Bosch SPDT relay will handle up to 30A safely which is WAY over kill for what you are looking to do but it will do the job!!
Posted Sep 22, 2009 · 22:35 UTC#20
Found a trick today...
If you change the language, the unit will reboot after. Of course, you have to then switch it back and reboot again...but at least you can do it while driving.
