Changing from Copied disc to New disc
By j76ms · Nov 03, 2006in General💬 7 posts👁️ 1,850 views
Posted Nov 03, 2006 · 17:00 UTC#1
Hello all,
I recently purchased a Sequoia that already had the AVIC-D1 installed in it. The dealership did not have the navigation disc for it so I ordered a copy off of ebay. It works ok for a few minutes and then starts making this clicking noise. Anyway, I have a friend that owns a custom truck shop and just realized that he could order the original disc for me at cost. He ordered me the same disc set that I have a copy of. CDNV-60MP or something like that. It is the 2006 version. My question is: If I put the new original disc in my AVIC-D1 will it run ok or do I need to erase the memory or something and re-install? I greatly appreciate any assistance and instructions if needed. I apologize if this has already been covered.
Thanks,
Jeff
Posted Nov 04, 2006 · 00:05 UTC#2
If the version is the same then you will have to do nothing except insert the DVD.
However, the clicking could be a sign of something mechanical, I hope it is just the copy... good luck.
Posted Nov 04, 2006 · 00:30 UTC#3
Did the copied disc have a label on it? If so, the label might not be centered properly, throwing the disc off balance and causing the clicking while it is spinning at top speed
Posted Nov 05, 2006 · 22:02 UTC#4
Yes this disc has a label on it. I have tried to smooth it out but it seems to be ok. I hope it is not mechanical. I am not sure how to fix it if it is. Thanks for your help.
Posted Nov 05, 2006 · 22:15 UTC#5
actually, if you reset the disk you will ensure pioneer and their backgrounds and splash screens are loaded. You can reset the unit just above the bottom left corner above the silver knob. theres a pin hole. Again, you would do this to ensure that the splash screen.. if changed.. probably hasnt though.. would be put back to pioneers stuff.
Hope this helps, enjoy
Posted Nov 06, 2006 · 14:01 UTC#6
So when I take the copied disc out and before I put the actual Pioneer disc in - I puch the reset button and then put the new disc in? Thanks for your help.
Posted Nov 07, 2006 · 01:28 UTC#7
I believe that works, I have always just put new disk in and then hit reset. but should work your way as well
