Navigation troubles - Need some help/advice
By DEA · Nov 04, 2006in Problems/Troubleshooting💬 8 posts👁️ 1,734 views
Posted Nov 04, 2006 · 07:17 UTC#1
I have had my D2 only a couple of weeks, but it does not seem to be working very good at all?? I have had it installed professionally, and they have also followed the bypass instructions here on this forum. It all seems to be working fine however, Here's my main issues:
1. Speed pulse will NOT work (nor Vehicle Dynamics - Calibration screen).
2. GPS/Map does not seem accurate. The guidance arrow will NOT stay straight. I have to constantly "modify" my location in the settings and even then, does not stay on the road, keeps turning all kinds of angles, and therefore does not even give me the name of the road/street I am currently driving on.
Does Anyone here have any advice or knowledge that could help me out?? again, my installer tells me the bypass is done from the info off this forum, and that the VSS wire IS hooked up.
Thank you so much to anyone that could help me out here.
Posted Nov 04, 2006 · 12:37 UTC#2
If you have no speed pulse reading at all, then either your installer is lying to you and lazy to try to find the wire, or simply an idiot and didnt hook up the right wire.
If your VSS was installed correctly, you would definitely have a speed pulse reading, as well as a better navigation reading while driving.
Posted Nov 04, 2006 · 12:42 UTC#3
I am sure it would help the board be more helpful, what kind of car is it in? Also curious to where the antenna is mounted?
Posted Nov 04, 2006 · 16:36 UTC#4
It is a 2006 Charger SRT-8 and the antenia is mounted on the roof, passenger side.
So if there is no speed pulse, then the VSS wire is for sure not hooked up then!! Thank you so much for the help.
Posted Nov 05, 2006 · 02:32 UTC#5
I had a similar issue with the guidance arrow not staying straight on roads. After messing with it and correcting location (which got old quick) I went into the 3D setting and told it to recalibrate. It's been totally fine since. I think it may have something to do with the internal gyro needing to be reset after installation.
I did have mine professionally installed and have the VSS.
~Chris
2007 Avalanche with iPod Integration, working OnStar and Factory Steering wheel control.
Posted Nov 07, 2006 · 05:02 UTC#6
i believe you are supposed to reset the unit after installation in order for it to correctly calibrate.
Posted Nov 07, 2006 · 13:07 UTC#7
There is also a setup option burried somewhere you should use if your unit is facing left or facing right in the vehicle.
Posted Nov 08, 2006 · 14:09 UTC#8
aslo check connection status to see how many gps satellites you're picking up.
