Need help quick trying to find vss wire for 09 escape
By hanibal · Jul 20, 2009in Problems/Troubleshooting💬 7 posts👁️ 743 views
Posted Jul 20, 2009 · 20:41 UTC#1
Have a f900bt and a 09 ford escape and can not find a vss wire for the deck? Please help as I am at the shop now.
Posted Jul 20, 2009 · 21:37 UTC#2
http://www.the12volt.com/
find your car there, I belive it's listed... if not google will be your best freind...
Just an FYI, you do not need to attach the VSS cable (I found this out thanks to Boris when I first got the unit.) Everything will work just the same with/without the VSS cable.
Posted Jul 20, 2009 · 21:41 UTC#3
Tried that site with no luck and without the vss the gps won't be accurate?
Posted Jul 20, 2009 · 21:42 UTC#4
Not at all, same exact speed.
I've done both with/without and had same results, only time you'll have a "issue" is if you loose GPS signal (under a tunnel or garage where there is no signal)
Posted Jul 20, 2009 · 21:45 UTC#5
Here ya go, took 2 min on google... not even... ;)
Control Lever: 250-3421 OR 250-3742
VSS Wire: UNDER HOOD ON FIREWALL 3 CONNECTOR PCM MIDDLE CONNECTOR POSITION 1 PURPLE/ORANGE
VSS Wire Color: PURPLE/ORANGE
VSS Pulse: 8000
VSS Tach Wire: IF MANUAL TRANSMISSION USE CLUTCH SWITCH 250-4206
Brake Switch Positive: GREEN/RED
Posted Jul 20, 2009 · 21:54 UTC#6
Tried that wire with no go on the gps. 1eve been trying all afternnon to find it so u say it will still work without it? (Hey told me to try it out without it and they will continue to search.
Posted Jul 21, 2009 · 18:56 UTC#7
Yea nav will work with speed as long as you dont loose gps signal
