F900 Dump file
By DarkMaster · Jul 22, 2009in Hacks/Mods💬 9 posts👁️ 3,090 views
Posted Jul 22, 2009 · 22:02 UTC#1
Could someone post the SDMLC file for an F900. I have been scouring this site and have yet to come across a copy.
I haven't bricked my unit but i need this file to possibly fix the error that the MSN direct is giving me"firmware update failed"...and of course Pioneer say"just send it back" with no guarantee or RMA number just a hope and a prayer that it will magically get back to me, so any help will be appreciated.
thanks
Posted Jul 22, 2009 · 22:54 UTC#2
I have a backup of my unit but my MSN direct is funky, and has been funky since 2 weeks after i got it(see above Post). If anyone wants it i will post it...but I would really love a copy that is known to work.
Here is the liink
IT DOES NOT WORK FOR ME, you however might have better luck.
http://www.4shared.com/file/119936749/c ... 09984.html
And I am still looking for a confirmed working Dump
Posted Jul 23, 2009 · 00:21 UTC#3
Aww cmon guys...this is easy...in fact testmode already has all of the tool you need to accomplish this little feat, It would fix(hopefully) my unit, and it only takes a few steps.
1: boot into testmode with the new version of it
Test mode can be found here http://itchybot.com/3.0%20Install%20Files.zip simply extract the folder called test mode onto an empty SD or USB drive, you can ;ignore all of the other files
2:select DiskRW
3:select read(should already be done) select SDMLC and give it a place to go in the propmpt(an SD or USB card )...
4:hit read
let it work until it says completed(should only take 48 sec)
5:upload the img file that was created on your card to a filesharing site or PM me.
Please note It has to be from an F900, if it is not my unit will not boot. Thanks in advance
Dark
Posted Jul 24, 2009 · 17:40 UTC#4
Anyone?
Posted Jul 25, 2009 · 12:01 UTC#5
2 DarkMaster, i shared my f90 UC dump before,
so, you can try use it at UC version
http://www.4shared.com/account/file/105 ... 09984.html
aso, i see baskup from you link, it also for UC, but also few bytes different also.
but i think problem not in SDMLC, if testmode working,
1) try wrute sdmlc
2) copy winceimg to sd and write it from uboot
3) back to testmode again
4) format my flash disk, and copy any backup to it
5) try reboot and check avic.
Posted Jul 25, 2009 · 21:40 UTC#6
1) try wrute sdmlc
Have yet to try an F90 but i do not think it will work...i think it has to be an F900
Also what are the other 2 disk selections for in DiskRW?
Posted Jul 27, 2009 · 00:56 UTC#7
2:select DiskRW
4:hit read
Dark
I know you need a F900-- mine is a f90 with the 3.0 version on it. If you get desperate and want to try mine, PM me; I am not sure I follow all the steps above (have never done them), but I'm comfortable with Testmode and WinCE...
Posted Jul 30, 2009 · 13:37 UTC#9
Hello,
I need please urgently a dump file for a F900BT EU!
With pleasure also by PM.The file from "foxyloxy" does not work with my F900BT.
Sorry for my bad English.
Thank you
