I did the N1 bypass today, and it works great. Then I noticed my front and rear left channels are cutting in and out. But they stay off more then then stay on. It almost sounds like it's grounding out. I took apart the N1 headunit, and rechecked all the screws. When I switched RCAS L-R and R-L then my left channel will work fine. I have a Zapco 4ch Reference amp, so that eliminated that problem.
When I removed the head unit, the wires were really tight pulling the head unit out of the din hole. You guys think there's a possiblity that the wires may have torn on the inside of the insulation?
Any suggestions? Get a new RCA output connector?
Thanks in advanced.
Posted Nov 06, 2006 · 00:39 UTC#1
