Handbrake / Bypass what one do i need
By zer0 · Jul 25, 2009in Problems/Troubleshooting💬 11 posts👁️ 1,991 views
Posted Jul 25, 2009 · 09:09 UTC#1
Hi just gotmyself a F900BT today and just ran into a bit of a boggle.
ive been looking around the forums to find out how to disable the "No Video while Driving" feature, found alot of helpfull info but none really answered all the questions i had... with most other head units ive dealt with this problem by just grounding the handbrake and this seems to do the trick, is this the case with the F900BT (AU) or do i need to do some sort of rewiring with the loom there aswel??
ive seen a couple posts where people are talking about a bypass method where they move the Mute cable from the from back of the head unit loom to another terminal on the loom. is this just to allow video playback while driving or does it have another purpose?
and i havnt seen anyone complaing about this but can the GPS reciever in any way foil the Handbrake / Bypass hack and lock you out if it detects the car is moving?
Any replies will be greatly appriciated kinda need answers quick cause im still tossing up weather or not i want to keep this unit or look around for something else...
Car: Nissan 350z 04
HeadUnit: Pioneer F900BT (Au)
Speaker: Stock Bose Speaker / Amp Setup
Posted Jul 25, 2009 · 12:58 UTC#2
Try the modifications FAQ
FAQ: Hacks & Modification :: READ BEFORE POSTING!
viewtopic.php?f=34&t=18977
Posted Jul 25, 2009 · 15:32 UTC#3
yep checked there already and found real easy instructions on how to do both the software / hadware bypass but what i want to knwo is what does this actually do?? is this the same as just grounding the handbrake cable? or wont this be enough...
Posted Jul 25, 2009 · 15:36 UTC#4
it allow you to watch movies on the go, be able to change/enter/edit your route if your navigating,
Posted Jul 25, 2009 · 15:37 UTC#5
also enabling you to use navigation and system settings
Posted Jul 25, 2009 · 15:50 UTC#6
wont just grounding the hand brake cable (light green) take care of this or do i need to follow the full bypass method
Posted Jul 25, 2009 · 15:59 UTC#7
Just do it. You'll like it. No questions, just do it lol
Posted Jul 25, 2009 · 16:02 UTC#8
i thought you already read the bypass thread? the how to won't be created if it's just a matter of grounding the paarking break wire, i don't want to be sounding like an ass or anything it's just that everythings already laid out, and it's just up to users to follow it,
Posted Jul 25, 2009 · 16:19 UTC#9
all is good ts just that ive install a fair few head units and never heard of moving the mute wire before just wanted to confirm this had to be done aswel,
Posted Jul 25, 2009 · 19:03 UTC#10
This would be *WHY* we have a FAQ and 3 different bypass threads! because simply grounding the e-brake lead from the unit doesn't work that way. This is all covered in the aforementioned Bypass threads you keep glossing over. If you just had to ground the e-brake lead we wouldn't have those threads and people constantly asking "how to I watch video/adjust settings when I'm moving"
Posted Jul 25, 2009 · 21:42 UTC#11
The Pioneer is not any other unit. The bypass will only work if done the right way. All other methods that you speak of have been tried and failed. Just follow the instructions for F series bypass and it will work. Trust us, this is the the place to go for this kind of stuff.
