How To: Read Wiring Info.
By cntrylvr79 · Nov 06, 2006in Vehicle Specific Wiring💬 13 posts👁️ 18,922 views
Posted Nov 06, 2006 · 01:49 UTC#1
So I get a couple pms a week asking me what I mean when I post up the wiring info for a car. So rather than have to explain myself each time I thought I'd make this post which will hopefully explain what it is when either myself or one of the other people on the forum replies with an answer for wire codes.
We'll take the following as an example. The wiring for a 2003 Mitsu Galant
Reverse Light red/blue + pin 9, 43 pin plug in DKP
Speed Sense yellow/black data link conn., R of column
the first thing is obviously what the wire is, reverse signal and speed signal.
The Second is the color. This is where some people get confused. The first color list is the color of the majority of the wire. The second color is the color of the stripe on the wire. Not all will have a stripe. So in the case of the reverse light it's a red wire with a blue stripe on it. And the speed sense will be yellow with a black stripe.
The final item is the location. Most of the time I try and write out the abbreviations, but sometimes I forget. So I'll list here the abbreviations I can think of and if anyone comes up with some I missed let me know I'll add them
DKP = Driver's kick panel (generally behind the area by your left foot if you were sitting in the driver's seat)
PKP = Passenger's kick panel ( same as above but right foot sitting in the passenger's seat.
DLC = data link connector aka diagnostics plug aka obd2 plug
GEM = Generic Electronics module. The computer in fords that controls convience items like door locks and such
BCM = Body Control Module
ECM = Engine Control Module
ECU = Engine Control Unit
ETACS ECU = Electronic Timing and Control System
PCM = Powertrain control Module
Harness to rear = Lift up the carpet on whichever side of the car it says, and you should seee a large bundle of wires that looks to run from the front of the car to the back.
that's all for now. Also if you're looking for wiring info, type in the model, make, and the words "merry xmas" the majority of my posts with wiring info will have those 2 words at the end to help locate. All in all have fun and happy installing.
Josh
Posted Nov 06, 2006 · 01:51 UTC#2
Stickied!
Posted Nov 08, 2006 · 08:51 UTC#3
im trying to locate the speed sensor wire in my o6 raider. is it the(white/orage) wire behind the stereo?
Posted Feb 09, 2007 · 08:28 UTC#4
Hey guys,
I have an 01 Chevy Tahoe and just installed the avic-d2. Just wondering what color the parking brake wire is in the back and what color the cell mute is? And what do i ground it to? Thanks for the help
Felix
Posted Feb 09, 2007 · 13:39 UTC#5
The parking brake wire is green. The cell mute wire is yellow/black. You have to move the cell mute wire to the empty slot in the harness first. Then hook both of them to the black wire in the harness.
In the future please create a new topic for your questions.
Posted Feb 13, 2007 · 04:46 UTC#6
Can anyone help me find the VSS & reverse wire on my '03 BMW 325i?? There isnt a round wiring harness under the hood on the passenger's side either. Diagnostic hook-up is under the dash on the drivers side
Posted Apr 16, 2007 · 16:04 UTC#7
i have a 2004 titan and need to know how to get to the back of my d3 to change the wires for the bypass
Posted Apr 17, 2007 · 02:58 UTC#9
For yalls sake just post the info for directechs... :idea:
Posted Apr 17, 2007 · 14:48 UTC#10
Umm I do, and audiovox and a couple others that I have access to. This thread was intended to help people who don't understand what the information means when it says things like driver's kick, etc. Remember installers think completely different than regular people do. We're speacial :lol:
Yes I know I spelled it wrong.
Posted May 14, 2007 · 03:33 UTC#11
How about a vss and reverse for 07 HHR
Posted May 14, 2007 · 14:45 UTC#12
How about posting the request in the right forum.
As far as your info goes, vss you'r only getting at a wheel speed sensor or if you get the lanbus interface.
Posted Feb 23, 2009 · 19:57 UTC#13
I need some help finding the color and location of the speed sensor wire and the color and location of the reverse sensor wire. I have 1997 ford explorer.
Any help would be appreciated
