3.0 - Updating arrows w/ vehicle?
By bsnively · Jul 25, 2009in Hacks/Mods💬 5 posts👁️ 1,348 views
Posted Jul 25, 2009 · 23:29 UTC#1
Is the process of updating he arrows for 8.3 the same as what's done for 8.0
I really just ended up taking somebody's data.zip file, and replaced the images in them (but am debating trying to do the right changes in the ui files as well)
Thanks,
Ben
Posted Jul 26, 2009 · 13:01 UTC#2
I would also like to change the arrow as well?
Posted Jul 26, 2009 · 15:48 UTC#3
for 3d - I am able to show the custom car image, but the arrow is still showing.
What I've done so far is:
1. Update the data.zip w/ custom car image.
2. In the navigatemap800_480.ui - add a sprite that has the image outside the screen view space.
3. update the navigate.ui (in common folder) to either place the car image at the right y position - or off the screen space (where it's initialized in the navigatemap800_480.ui).
The only issue I have is the 3d arrow still shows w/ the car image. Does anybody know how to eliminate the arrow in that mode?
Will investigate further - figured I would give an update.
Thx,
Ben
Edit: forgot one step - I updated the [map] section in the sys.txt to have:
3d_scale_carmodel=1
3dcarsizemin=3500
3dcarsizemax=5000
3dcarsizemul=10000
Posted Jul 26, 2009 · 21:35 UTC#4
this post might help you
viewtopic.php?f=34&t=17490&start=45#p116696
I tried changing the 2D arrow to a bmp by just replacing the files but it doesn't seem to work. I rezipped the DATA.zip file and put it on my head unit, and now when I hit map, it just reboots.
These are my files:
http://myfiles.neu.edu/willard.mi/avic4 ... daycar.bmp
http://myfiles.neu.edu/willard.mi/avic4 ... rghost.bmp
http://myfiles.neu.edu/willard.mi/avic4 ... ghtcar.bmp
Posted Jul 27, 2009 · 12:13 UTC#5
Those are pretty much the steps I took - maybe I'll try that exact configuration for the sys.txt - but the rest of the steps are what I did for the above post...
