PLEASE! HELP!! My system will not recognize my usb hardrive,flash memory, or sd card.
As you all may know, this is needed to get me on my way and use all the useful, and helpful hacks on this forum.
Help! Help! Help! ![]()
when do you try to access sd/usb? during FW upgrade?
Which version of Testmode are you trying ? is the sd card it is on formated in fat 32?
Actually, the H/U I installed came with the 3.0 firmware installed already. I never tried to use the SD card until recently, and only used the USB port for the Ipod. When I inserted the SD card I was trying to view a few jpeg pictures. I didn't reformat it to fat32, either way, it's not illuminated as an option on the source screed. The same is with the USB port. I know it works because the Ipod works fine, and I've read the thread on the 2.5v for the external hardrive.
Not to sure, and I'm sure you all will agree, if it makes any sense to make the modifications for the external hardrive if it's not exactly the problem.
Any other suggestions??? ![]()
Reinstall WINce update by format method
Reinstall My Flash Disk
DonMac???
I'm not sure if you are understanding my dilema??? I CAN'T USE the SD Port. How am I going to reinstall the update?
Don't you need to download it and apply it to the SD as some sort of zip file, and then open it on the head unit?
Just a suggestion, format an SD card fat32 and put a couple of mp3 files on it and see if it is then recognised.
The reason I say this is that you seemed unsure about the format of your SD card and if it is wrong it will be greyed out in the menu.
mine wouldn't read my SD 16gb card until I formated with FAT32 on a windows computer.
SD card is FAT 32. It can only be read through a SD card reader attached to the usb cord. But I'm not sure if I can do any hacks such as screensaver etc. etc. through the usb cable
Reinstall WINce update by format methodReinstall My Flash Disk
DonMac???
He meant flashing WINCE in service mode.
You should be able to start testmode from USB using this http://www.4shared.com/file/139589057/2 ... e_USB.html . Just unpack it to a USB flash drive, plug in and cold start the avic. Once booted from USB you should first check if a well formatted SD card is recognized by windows when inserted.
As the Unit came with 3.0 it must be brand new. I would contact the dealer before I go down any other route. If the SD drive does not recognise a FAT 32 SD it may be faulty and your whole unit subject to exchange.
Did you really try to reformat the SD completely? How big is it? I think only SD's up to 8GB are guaranteed to work with the AVIC. As said before: Reformat and put some MP3's on there. If that doesn't work: See your dealer! It doesn't make any sense to fxxk around with a brand new faulty unit and risk the warranty.
Jörg
