I am installing an AVIC F700BT in a 2000 Corvette C5 and have a couple of questions. Point of reference I am a total newbie to installing electronic equipment, hence the simplistic nature of my questions. I have completely torn out the interior of my vette and I've done a number of upgrades so I can do it once I have the info. Also, I did a search and have partial info I need (Thanks!!) but can someone help with a clarification and a couple of questions
1. I understand the F700BT does not need/require a VSS wire. I thought this was absolutely necessary for navigation. How much loss in navigation ability will result from not having the VSS hooked up? I've read some post where members indicate not much loss but can someone confirm how much degradation? Does running the reverse wire somehow compensate for the VSS? I'm not going to play DVD's and that's why I didn't get the 900 series but now I'm concerned I have much less of a nav unit than I hoped for with the absence of the VSS....
2. I see some posts recommending the purchase of a wiring harness? Doesn't Pioneer supply everything necessary to install? If so what does the harness get me?
3. I am keeping the stock Bose speakers but have an adapter from Peripheral to be able to run my stock speakers with the AVIC. I purchased used and don't have the install instructions. Dumb question: Where do I plug the Peripheral to stock setup and then to the Avic?
Thanks for the great support and information.
