When I removed my stock stereo from my VW Jetta, it would remain on when I killed the engine, but the key was still in RUN. Same deal if the car was completely off, if I turned the key to RUN or ACC, the stereo would stay on, and when I went to start the car, it would continue to remain on.
I've had the AVIC F-700BT installed for a year now, and it seems to shut off and every stage. If I kill the engine, the f700 has to reboot.
If I'm in RUN or ACC and the stereo is fully booted, then go to start the car - again, it has to reboot.
Is there a way I can wire the stereo to remain on (except when there is no key in the ignition or the ignition is OFF)
Thanks.
