2d arrow position
By eppler · Jul 26, 2009in Hacks/Mods💬 6 posts👁️ 761 views
Posted Jul 26, 2009 · 22:27 UTC#1
Are there x and y settings for the 2d arrow position?
Posted Jul 26, 2009 · 22:41 UTC#2
AFAIK its by percentage, check out this code from navigatemap.ui
map.SETCARPOSITION 50 50
that means its 5o% horizontal and 50% vertical or vice versa
Posted Jul 26, 2009 · 23:09 UTC#3
The problem is my arrow sits off center to the left and to far forward can this be fixed?
Posted Jul 26, 2009 · 23:31 UTC#4
play with the values, not sure where it's referenced to but playing with the values would most likely get you where you want to be
Posted Jul 26, 2009 · 23:44 UTC#5
I did but it moves the map and arrow and is still off the mark.
Posted Jul 27, 2009 · 00:23 UTC#6
could you post the code that you changed, i currently don't have 8.3 files with me,
