I got a new iPhone from work yesterday and it will not connect to my F90bt via bluetooth. Do you have to use it with the supplied usb cable to use it as a phone?
iPhone 3GS Issue
I recently purchased an iPhone 3Gs model myself, and have connected it via Bluetooth successfully. No need to connect it to the F90 via the USB cable.
Try a couple of times (if you haven't already) as I seem to remember it taking more than once, but I have indeed done it.
Good luck!
Cheers,
Kev
Thanks for the info. I will keep out it. I do imagine that you have to connect it vis usb to listen to music on it though..
Yes, that is correct - you will need to connect both the USB and dock connections via either the Pioneer supplied cable or the Apple one others have purchased seperately to listen to music from the phone.
(Edit: One thing to make sure of though, that your Bluetooth setting on the iPhone is turned on so that it is "discoverable" to the AVIC)
To listen to music you need to connect the Audio Cables, the USB cable is to be able to control via the HU.
I was able to setup my phone via bluetooth on the first try.
