different cars 3d in x910
By dashtwo · Jul 29, 2009in Hacks/Mods💬 8 posts👁️ 1,462 views
Posted Jul 29, 2009 · 18:31 UTC#1
don't know if this has been brought up yet but in the gfx folder of the x910's data.zip there are some new .mdl files that aren't in the f one:
car_ghost.mdl
car_blaupunkt.mdl
becker_car_gps.mdl
becker_car_ghost.mdl
i dont have any 3d software to see what these models look like but might try them out when i get home. hopefully one is better than the spaceship from the f series.
Posted Jul 29, 2009 · 19:12 UTC#2
car_ghost.mdl
car_blaupunkt.mdl
becker_car_gps.mdl
There's pretty much nothing available (outside of NNG's dungeons) that can view their 3D models. Blaupunkt one should be a triangle in a circle, though. Not sure about Becker.
Posted Jul 29, 2009 · 19:48 UTC#3
thanks, i guess i will use the avic to view them.
in 2.0 i managed to change my red arrow to gray by renaming the gray one to car.mdl since i am sure there is an easier way, do you know if i edit the [model] entry in the color3d.ini in each scheme will this work or do i also need to edit another .ini
[model]
car="car.mdl"
car_ghost="car_grey.mdl"
thanks again i am just learing.
Posted Jul 29, 2009 · 21:27 UTC#4
[model]
car="car.mdl"
It should be possible to set them in SYS.TXT as well.
Posted Jul 30, 2009 · 19:38 UTC#5
thank you for your help BorisM, unfortunately i am not getting very far.
my sys.txt does not have the [model] heading. should i add it in or put the entries
car="becker_car_gps.mdl"
car_ghost="becker_car_ghost.mdl"
under the [3d_config] (or some other) heading?
Posted Jul 30, 2009 · 19:42 UTC#6
Something like this, I believe:
[3d]
car_day=car.mdl
car_night=car_night.mdl
ghost_day=car_ghost.mdl
ghost_night=car_ghost.mdl
Posted Jul 30, 2009 · 22:01 UTC#7
not too great :)
car_blaupunkt is a red triangle with a green ring around it
becker_car_gps is a more 3d looking gray arrow with a 3d ring around it
thanks again BorisM
Posted Jul 30, 2009 · 22:08 UTC#8
not too great :)
thanks again BorisM
You're welcome.
Supposedly there was one person on one of the Russian forums who knew how to convert standard 3D models into iGO's format. He did a couple of Russian cars and disappeared...
