Avic N1 to Z
By charliex · Jul 29, 2009in General💬 5 posts👁️ 1,342 views
Posted Jul 29, 2009 · 22:31 UTC#1
I'm thinking of upgrading my N1 to a Z since the ribbon cable failed and i'm a bit tired of fixing stuff with it.
Some of the rear plugs look the same from the pics i saw, which means nothing, so does anyone have info on whether or not its pin compatible, same, mostly or not at all ?
Posted Aug 01, 2009 · 20:03 UTC#2
No, you will have to switch harnesses and plugs. Should take you about three minutes
Posted Aug 12, 2009 · 02:09 UTC#3
Thanks CT, i ended up just repairing the flex cable on my N1, since i already had it apart it actually took less than 5 minutes since the flex cable had just partially split.
Posted Aug 12, 2009 · 04:04 UTC#4
N1!!!! Man get a new unit already. :wink:
Posted Aug 13, 2009 · 18:04 UTC#5
I almost did, but played around with some of the newer double DIN's and didn't see anything that really made me want to jump over. Plus i haven't finished hacking the rom of the n1, i'm determined to remove that warning in code one day. then i'll buy a new unit ! :0
