Hello All. I am having troubles with my unit (F700BT) playing an iPod. The radio, both FM and AM, works great and both sets of side speakers (left and right) sound great. Not the same when I switch to listen to the iPod. The left speakers sound great, where as the right speakers (both front and back) sound very muffled and lower volume (almost as if they are blown out). They can not be blown out though because, as I have stated, the radio works great, along with the "beep" sounds when buttons are pressed. Has anyone else had this problem and is there anything I can do to correct it? Here are some things I am going to try tomorrow: 1) play ipod using 3.5mm cord 2) play music from flash drive using USB inupt (same as ipod). Anything else you pros can think of to try? or is this a common problem that cannot be fixed and I should call Pioneer to try and get a replacement unit?
Thanks for any and all help! I hope I can get this issue sorted out ASAP
