Z1 wiring question - 05' Ford Explorer
By ffd173 · Nov 07, 2006in General💬 12 posts👁️ 2,171 views
Posted Nov 07, 2006 · 03:51 UTC#1
Hi all. I have a quick question about installation.
My unit was installed 4 months ago. It works great. But the installers didn't hook up my speed pulse sensor wire. I know I don't need it, but I also know that it is more accurate that way.
What wire in my 05' Explorer do I connect the Z1 to for the speed pulse sensor? :?:
Thanks in advance for the help!!
8)
Posted Nov 07, 2006 · 04:04 UTC#2
If it's anything like my 03 Lincoln Aviator (should be, I think they are pretty close) there is a gray wire with a black strip on one of the plugs for the radio. At least my radio came with speed sensitive volume. Just tap off that. If you don't have that connection behind the radio, then you will have to hunt it down somewhere else. The guys here seem to be able to look up wire info. I don't know where else it might be in your Explorer. But I just did a friends F250 and that was on the antilock brake module and it was gray with a black stripe as well. So look behind the radio for that color.
Posted Nov 07, 2006 · 04:08 UTC#3
Wow. Thanks for the quick reply!!
My factory unit DID have speed sensitive volume so I would expect there to be a wire for it behind the radio. With your advice, I now know what color wire to look for. I will post my findings tomorrow after I give it a try.
Thanks again!! I appreciate it.
:lol: 8)
Posted Nov 07, 2006 · 12:46 UTC#4
No problem, yes, if your truck did come with speed sensitive volume, I would guess there is a little square like connector with 20+ positions for wires but mine only had 3 wires. The VSS was gray with a black stripe, the steering wheel controls and the mute wire for the rear sensor (which you can hook to your cell phone mute wire if you want to).
Posted Nov 07, 2006 · 18:30 UTC#5
The main connection from the vehicle that connects to the Z1 has a gray wire w/black stripe, but it is connected straight through to the front speaker connection of the Z1. The all gray wire and the gray wire w/black stripe are for one of the front speakers.
I'm going to check one of the other connector blocks behind the radio that are not being used and see if one of those has a gray w/black stripe wire on it.
Any other suggestions? Let me know please.
Thanks.
:( 8)
Posted Nov 07, 2006 · 20:13 UTC#6
No, it's not on the main connector. It's on a separate connector. Not the one with power and speakers. But in general the connector in your car that has the VSS is not used in a general Z1 install. That connector only has backup mute, VSS, and steering wheel control.
Posted Nov 07, 2006 · 21:35 UTC#7
OK. I did the following before I read Ducatiboy's last post.
On the main connector from the vehicle, I in fact found the gray wire w/black stripe. The main connector is connted to a Ford wiring adapter which is then connected to the Z1. I followed the factory gray/black wire into the first adapter and it changed to a white wire. I followed it through to the second (and final) adapter which connects to the Z1. It does not go through the second adapter. So I just cut the white wire and attached the pink speed sensor wire from the Z1 and it seems to work great. I started driving and the speed pulse indicator started counting up and the 3D calibration status said "Sensor initializing". I am assuming that I have it hooked up correctly.
If anyone doesn't think that I have it correct, please say so.
:lol: :lol: 8) 8)
Posted Nov 07, 2006 · 22:21 UTC#8
I guess I got it right. It now shows my 3D calibration status as 3D Hybrid.
Woo, hoo!!!!!
I love it when things actually work the way they are supposed to!
:lol: 8)
Posted Nov 07, 2006 · 22:26 UTC#9
Cool, glad you found the right wire. If you are in 3d hybrid, you are good to go. My descriptions were based off the 03 Aviator (with the assumption that the 05 Explorer would be the same). Guess it was close but not exact. Glad you found it!
Posted Nov 07, 2006 · 22:38 UTC#10
Thanks again to you ducatiboy.
I also just ordered one of your flasher circuits. I paid with paypal funds.
Let me know how soon you will ship it. No rush, just want to know when to expect it.
Thanks again for all of your help!! This site is the best!
:lol: :lol: 8) 8)
Posted Nov 08, 2006 · 00:09 UTC#11
:lol: :lol: 8) 8)
No problem, I hope I was at least a bit helpful. Sorry I didn't know exactly where the ILL wire was on your truck. As for the order, I noticed the order and it should go out tomorrow from NJ via USPS Priority mail.
Posted Nov 08, 2006 · 22:45 UTC#12
Thanks for the quick ship Ducatiboy, it's appreciated!
I have come across a wiring diagram guide for my 05' Explorer. I am attaching it for anyone who might find it usefull.
2005 FORD EXPLORER 4DR SUV WITH 4.0L ENGINE AND MACH® AUDIO SYSTEM
Audio
Battery WHITE/YELLOW (+)
Accesory BLACK/PINK (+)
Ground BLACK/ORANGE (-)
Illumination RED/BLACK (+)
Amp Turn On BLUE/RED (+)
LF Speaker (+) ORANGE/LIGHT GREEN
LF Speaker (-) LIGHT BLUE/WHITE
RF Speaker (+) WHITE/LIGHT GREEN
RF Speaker (-) DARK GREEN/ORANGE
LR Speaker (+) GRAY/LIGHT BLUE
LR Speaker (-) TAN/YELLOW
RR Speaker (+) ORANGE/RED
RR Speaker (-) BROWN/PINK
Amp Location BEHIND TRIM IN RIGHT REAR CARGO AREA
Steering Cntrls OPTIONAL
Speed Cntrl OPTIONAL
Radio Security YES
Security
Battery YELLOW (+)
Ignition 1 RED/LIGHT GREEN (+)
Starter 1 RED (+)
All Door Trigger BLACK/LIGHT BLUE (+)
Domelight Super BLACK/LIGHT BLUE (+)
LF Latch YELLOW/BLACK (+)
RF Latch GRAY/RED (+)
LR Latch LIGHT GREEN/YELLOW (+)
RR Latch PINK/LIGHT BLUE (+)
Trunk Trigger WHITE/VIOLET
PIN #12 (+)
PIN #12
Hood Trigger TAN/LIGHT GREEN
PIN #11 (+)
PIN #11
Alarm Disarm DARK GREEN/VIOLET (-)
Parking Lights BROWN (+)
Remote Start
Battery YELLOW (+)
Accessory 1 DARK GREEN/LIGHT GREEN (+)
Starter 1 RED (+)
Anti-Theft Type FORD PATS® OR SECURILOCK® VEHICLE IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense BLACK/LIGHT GREEN (+)
Neutral Safety WHITE/RED (+)
Tachometer GRAY (AC)
Crankshaft Sensor GRAY (AC)
Camshaft Sensor GRAY/RED (AC)
Speed Sense GRAY/BLACK (AC)
Brake Lights LIGHT GREEN (+)
Reverse Lights BLACK/PINK (+)
Horn DARK BLUE
PIN #6 (+)
PIN #6
PCM - POWERTRAIN CONTROL MODULE ABCM - ANTI-LOCK BRAKING CONTROL MODULE CSM - CENTRAL SECURITY MODULE
Module 2 ABCM - BEHIND DRIVERS SIDE HEADLIGHT
Module 3 CSM - BEHIND TRIM NEAR RIGHT REAR SEAT
Doorlocks/Windows
Power Unlock PINK/GREEN
MAY ALSO BE FOUND AT CSM MODULE (-)
PowerLock PINK/YELLOW
Driver Mtr Unlock PINK/BLACK (REV)
Driver Mtr Lock RED/ORANGE (REV)
Pas Mtr Unlock PINK/BLACK (REV)
Pas Mtr Lock PINK/ORANGE (REV)
LF Window Up TAN/LIGHT BLUE (REV)
LF Window Dn RED/YELLOW (REV)
RF Window Up YELLOW/RED (REV)
RF Window Dn WHITE/BLACK (REV)
LR Window Up BROWN (REV)
LR Window Dn BROWN/YELLOW (REV)
RR Window Up BROWN (REV)
RR Window Dn BROWN/YELLOW (REV)
Sunroof Open WHITE/RED (-)
Sunroof Close TAN/RED (-)
