WINCE+Format Or No Format?
By 69sixpackbee · Jul 31, 2009in Hacks/Mods💬 4 posts👁️ 1,038 views
Posted Jul 31, 2009 · 17:54 UTC#1
I have been tirelessly reading all of the post about updating to 3.0 (then 3.01) and the GREAT instructions says NOT to do format but others do use the "with format" option. My V2 has been through considerable mods and is working well but I am hesitating which update procedure to use. Is the one WITH format okay to use or should I just use the standard update?
Thanx for the help guys!
Bud
Posted Jul 31, 2009 · 18:27 UTC#2
Bud
I updated my F900BT using the files from the next thread(1):
viewtopic.php?f=34&t=25751
And used the APL / APL2 from the EU Deck thread(2):
viewtopic.php?f=34&t=25743
I updated the WINCE with Format, copied the files from thread(1) to my Flash disk and copied the apl/apl2 from thread(2) over it.
This worked for me!
Gr
Galadril
Posted Jul 31, 2009 · 18:54 UTC#3
the Short answer is this:
Back up anything from 2.0 you want to save, custom files and user data, etc.
and then do WINCE update WITH FORMAT.
You can upgrade to 3.0 from 2.0 without formatting, but you CANNOT go to 3.01 without first formatting when you do the step from 2.0 to 3.0.
The reason being is that 3.01 includes a new UnitedStates.DEM file that is 118 megabytes uncompressed that WILL NOT FIT on your flash drive if you go from 2.0 to 3.0 without formatting. Even without mods, a 2.0 to 3.0 "Copy Over" upgrade only leaves you with about 30 megs +/- of available space on "My Flash Disk".
The only way you can do it without formatting is to first delete a significant amount of maps you don't think you will need before going to 3.01. Me personally, I like to have everything stock before I start modding to rule out problems cause by missing files.
Posted Jul 31, 2009 · 19:44 UTC#4
Great explaination!
Thanx a bunch, Danno :)
