I previously had what I thought was a low end Premier unit which I replaced with the AVIC-F90BT. My vehicle was setup primarily for sound quality utilizing Focal components front and rear on amps delivering 200 watts per channel and a JL Audio 13W7 running at 1000 watts at 3 ohms. (not a light weight system) It sounded very good until I put the F90BT in there. Suddenly the bass got muddy and the mids all run together. The detail and accuracy are gone from the system. There is nothing musical about it at all. I went back to the audio shop I use and one of the guys there just installed one of these units in his vehicle and is suffering from the same exact problem. At this point I have determined that the SQ is the worst using the preamp outs, just bad using the speaker outs to the amps, and plain terrible if you just skip the amps all together.
At this point my only hope lies in the cute little Digital port on the back of this unit. Does anyone know what this outputs? Can you connect a DAC to this port and skip the internal apms and preamps? Will the nav and phone still work? I'm thinking about connecting an inexpensive Cambridge audio DacMagic (on an inverter) to the F90BT's digital out and going form the DAC to the amps. Any thoughts?
