Z-1 installed with Bypass no phone dial
By kennedd · Nov 07, 2006in Hacks/Mods💬 9 posts👁️ 2,551 views
Posted Nov 07, 2006 · 13:06 UTC#1
Hello, I just installed my z-1 (Sept 06) in a 07 avalanche using the wire bypass I have Ipod, xm, Sirius and bluetooth, everything works fine except I cant dial out with the HU unit. I can use the phone to dial and the bluetooth will pickup the call but if I try to dial from the address book or any of the poi nav screens it just jumps to the map. I am using a Treo 650 cingular. Any ideas or is this normal?
And by the way I could not have installed this monster myself without all the information on the site thanks to all of you.
Posted Nov 15, 2006 · 03:47 UTC#2
You stated that everything else worked, so the BYPASS DID work? The guys that are installing mine said that the bypass wouldn't work with Sept. '06 models (but they could just be telling me that)... So, does anyone know if in the last month or so, if Pioneer has somehow changed the design or wiring of the unit to disable the bypass noted in the stickies? I have yet to try the bypass myself, but give me 24 hrs and I'll let you know how it works...
Didn't mean to hijack the thread, but, then again, I kinda did... :lol:
Posted Nov 15, 2006 · 03:56 UTC#3
September 06 units are absolutely able to be bypassed, you use the 07/06 bypass on this page:
http://www.sminntech.com/z1flash.html
As for your Treo, I don't know about that, but it sounds like it's not a bypass thing but a treo compatibility thing. I don't know how to fix that. Smart phones are notoriously poor for connecting to bluetooth devices like the Z1.
Posted Nov 15, 2006 · 03:59 UTC#4
So, pretty much you are a Superhero, right DucatiBoy? Because you certainly saved the day here for me...
Posted Nov 15, 2006 · 04:04 UTC#5
Thanks, I try to help out here when I can. I just wish I had a fix for kennedd.
Posted Nov 15, 2006 · 14:34 UTC#6
You are correct the Bypass is not the problem. I have tested the system with a Razr and it works as well as everyone elses. It is a shame that the echo problem is not resolved.
Posted Nov 15, 2006 · 16:15 UTC#7
I have a September 06 model. No problems with the bypass :)
Posted Nov 23, 2006 · 02:58 UTC#8
how bad is the echo for bluetooth i got a Z1 with the bypass Oct 06 model also will it work with a samsung A640 , o and in the V D screen slope wont work is that beacuse the gyro is bypassed if so the g force still works?
Posted Nov 27, 2006 · 19:13 UTC#9
I am having the exact same problem. My phone is a Nokia N93 and I can't dial out using the Z1.
Is anyone using this type of phone and not encountering this problem?
