phone call
By higherlevel28 · Aug 01, 2009in Problems/Troubleshooting💬 10 posts👁️ 1,310 views
Posted Aug 01, 2009 · 19:37 UTC#1
any1 can tell me why i cant hear any1 when i try makein a call after i bluetooth it to my F series radio? the call went thru but cant hear the person....thank in advance...
Posted Aug 02, 2009 · 03:47 UTC#2
Is it synched correctly? Did you turn the phone convo volume up??
Posted Aug 03, 2009 · 19:06 UTC#3
yes, i did turn the phone convo upon the phone
Posted Aug 04, 2009 · 15:49 UTC#4
use the other BT firmware level than the one you are using right now.
Weo
Posted Aug 04, 2009 · 18:01 UTC#5
hey weo, whats BT firmware? thanks in advance for your help...
Posted Aug 04, 2009 · 21:10 UTC#6
go on pioneers website and search F series BT update/upgrade
Posted Aug 05, 2009 · 11:10 UTC#7
BT = BlueTooth
bear in mind that by "other" I mean "not the one you are using right now". Basically if you have 3.3, you should go to 2.9, and vice versa...
Weo
Posted Aug 16, 2009 · 18:44 UTC#8
good day, i change my blue tooth from 3.3 to 2.9 as reccomended but still yet am havein problem, when i make a call on my unit F900 the person can hear me but i still cant hear them and my mic is connected, any1 can help?
Posted Aug 18, 2009 · 17:54 UTC#9
my guess would be bad wiring. check the harness?
Posted Oct 10, 2009 · 17:37 UTC#10
good day all, form i bought my f900 unit am having problem make call on it, bt connect well, ph book copied but when its time to make or receive calls i cant hear nothing the unit just go in silent mood, i update the bt its the same thing, check connections everything connect properly. can any1 asset me???
