Microphone quality
By kbradford · Aug 02, 2009in General💬 22 posts👁️ 9,426 views
Posted Aug 02, 2009 · 01:59 UTC#1
So just got my U310BT all installed and it seems to be working nicely. My only complaint is that I the voice quality when using the microphone over BT is horrible. People sound great on my end, but I sound "far away" to everyone else. This is even if I talked directly into the microphone.
Is this a common problem with other Pioneer units? Is it possible to get a different microphone that may work a bit better?
Posted Aug 02, 2009 · 03:00 UTC#2
I haven't had any complaints calling people.
Posted Aug 07, 2009 · 10:33 UTC#3
I have the same issues. I can just about swallow the mic and people on the other end say I sound distant. Has anyone found a way to turn up the mic sensitivity?
Posted Aug 08, 2009 · 02:41 UTC#4
It's a Bluetooth / Setup thing- not necessarily the unit. The microphone placement will have a big effect on the quality- you may want to experiment with different spots. Mine is on the top of my steering column. You may also want to delete the phone from the Bluetooth profiles on the headunit (and delete the headunit from the phone) and re-pair the devices with the handset volume at a different level. I'm not sure how/why this works but it's worked for me before.
Posted Aug 17, 2009 · 19:17 UTC#5
What types of phones are you all using? I have the HTC Touch Pro and it works awesome. It may be some timing or connection issues with the BT.
Posted Aug 28, 2009 · 14:45 UTC#6
working with a lot of different bluetooth systems I have found that sometimes the quality can be hit or miss. sometimes in my car people tell me i sound crystal clear and the next day someone will tell me they can hardly understand me.
my thought is that sometimes when your phone links up it grabs a nice strong bluetooth connection and the next time it might be weaker. perhaps similar to why sometimes a cell phone call is cutting in and out but if you hang up and try again it will be fine even though you are in the same place.
also, other factors may affect it as well. it could be that the phone you are using has issues with bluetooth . it could be the location of the mic. it could be the mic itself isnt functioning properly. a lot of factors could come into play.
Posted Sep 06, 2009 · 23:00 UTC#7
Hi Guys,
I think I did enough research on this. It is the Microphone problem. I posted a mini review and also provided info about Microphone.
I replaced mine with Garmin Mic like few people suggested, now it is much.. much better. Actually it was not usable at all, with new Garmin Microphone it is reasonbly good, but not as good as my other Bluetooth system in my Prius.
Here is link for Mic at frys, it is very cheap.
http://www.frys.com/product/4865730
Hopefully, this will solve your problem too.
Posted Dec 07, 2009 · 00:12 UTC#8
I had the same issue...only it wasn't actually the mic at all...make sure that when you push the radio into place, the mic plug doesn't pull out a little...the first time I tried to call someone, they said they could just barely here me. Like I was a thousand miles away! I pulled the radio back out to remove the mic only to see it was loose...I plugged it all the way in and installed the radio again. Called someone...same issue. Pulled radio again and again plug was out. This time I pushed radio into place...then I reach under the radio to check the plug...again it was loose...I pushed it in. Called someone...perfect...person on the other side said they couldn't tell I was on speaker. So...make sure your mic is actually plugged in. It seems to pull out easily
Posted Dec 07, 2009 · 06:07 UTC#9
Atleast in my case it was not issue, as I bench tested this Mic without even installing the unit completely into dash. Also, I anchored all my cables so they would not pull out because of some load on cables.
But again, putting a dab of silicone may not be bad idea.
Posted Dec 27, 2009 · 03:03 UTC#11
I second this. The Garmin microphone improved things dramatically for me and I am very happy with the quality, especially for the price.
Posted Dec 27, 2009 · 08:26 UTC#12
I'm getting poor quality with the supplied mic. Has anyone tried anything other then the Garmin ? I'm looking at this Olympus ME-15. Here is the link http://www.newegg.ca/Product/Product.as ... -_-Product
That is only 3 feet in length, and meant to use tie-clip mic. IMHO You better off with $13 garmin mike than that $30 MIC.
Posted Jan 09, 2010 · 04:18 UTC#13
post install mic report....per advice on this board I didn't even install the OEM mic and subbed the Garmin recommended here...abs. no complaints from any callers, none can tell i'm on speaker phone.
Posted Jan 12, 2010 · 17:54 UTC#14
agreed! Garmin sounds much better than Pioneer provided mic!
Posted Mar 02, 2010 · 17:03 UTC#15
I got some complaints from people with my Pioneer Mic... I uninstalled the unit when I sold my car and am about to install in my new one, but I ordered the Mic from Amazon for $5 with free shipping.
http://www.amazon.com/Garmin-External-M ... B000F7A832
Posted Mar 19, 2010 · 13:18 UTC#16
I guess being last does have it's advantages sometimes. I just bought one of these u310's and my mic gain was terrible. After reading all these complaints, I called Pioneer and their tech said they were randomly haveing mic issues and they would send me another. We'll see.
Nice forum BTW.
8)
Posted Apr 07, 2010 · 21:03 UTC#17
Do i need to uninstall (take out the radio) and reinstall, if I need to replace the Pioneer Mic with new garmin one. I have my install scheduled for tomorrow and this Mic not available in local stores in Delaware. Is it easily pluggable from outside after the install? thanks
Posted Apr 07, 2010 · 23:33 UTC#18
It is behind the radio, and do not think Microphone can be replaced without taking out the head unit, unless you have open access to area behind the head unit. ( most cars do not).
Posted Apr 08, 2010 · 21:59 UTC#19
thanks for the reply..
Posted Jul 14, 2010 · 03:22 UTC#20
i purchased the garmin mic because the mic that comes with the headunit really sucks but i wanted to get a opinion what is the best place to put the mic.
Posted Jul 14, 2010 · 04:52 UTC#21
Chinna, which Garmin microphone did you get? Can you give us the model# or a link to the one you purchased? Also, how does the Garmin work in your opinion?
Posted Jul 16, 2010 · 16:25 UTC#22
Yes, the Pioneer is almost useless, and garmin microphone is usable and good.
This is the one I bought http://www.frys.com/product/4865730
But, it seems same one sold by Amazon and several other vendors. If you see the shape you will recognize it (Kenwood, Clarion, Parrot all use same Microphone).
