arrow size adjustment?
By nguyenphananh · Aug 02, 2009in Hacks/Mods💬 15 posts👁️ 3,677 views
Posted Aug 02, 2009 · 06:02 UTC#1
I just updated my 500BT with 3.0 update software from Pioneer (legit copy). Everything work well except the arrow seems to be much smaller the arrow from 2.0 ver. Anybody know what I can do, edit data.zip...etc... to make the arrow bigger? I figure this shouldn't be hard. Thank you
Posted Aug 02, 2009 · 06:07 UTC#2
Also I did a speedcam hack, using the code posting here. The camera warning showed up, but no warning sound. Can someone let me know what I need to do to get the warning sound back. I had this hack on my 2.0ver and it was working perfect. Update to 3.0 erase everything.
last question, I updated using the software bought from Pioneer. Should I update it to 3.01 ver that post here on this forum. Thank you
Posted Aug 02, 2009 · 17:41 UTC#3
you have to edit your sys.txt, add this to the [map] part
3dcarsizemin=2500
3dcarsizemax=5000
3dcarsizemul=15000
also, you have to play with the values as i'm still trying to figure out the best setting for it
Posted Aug 02, 2009 · 17:50 UTC#4
thanks bro,
I will try it right now, will let you know the result. Also you know the answer for the other problem? getting the warning sound for speedcam back? thanks in advance
Posted Aug 02, 2009 · 18:38 UTC#5
the arrow work perfect !! however it was still alittle small for my taste, so I increase the "carsizemin" up to 3500 and now it is just like how I wanted. Thanks
3dcarsizemin=2500
3dcarsizemax=5000
3dcarsizemul=15000
Posted Aug 03, 2009 · 00:18 UTC#6
3dcarsizemin=2500
3dcarsizemax=5000
3dcarsizemul=15000
no prob
Posted Aug 03, 2009 · 13:51 UTC#7
i changed the values in the pioneer.ini in the project_config folder. is this any different from the sys.txt change? I used:
3dcarsizemin=3000
3dcarsizemax=5000
and the arrow is just how i want it (except for color).
changing the sys.txt would be the easier of the two but i wonder what priority the unit reads this in.
Posted Aug 03, 2009 · 16:25 UTC#8
Im not sure, but I changed the value in sys.txt and it works. The arrow is as big as I wanted. I changed the carsizemin number, dont know what carsizemax number for?? also carsizelm?? but Im happy so far
Posted Aug 04, 2009 · 00:09 UTC#9
Where is the sys. text document located?
Posted Aug 04, 2009 · 01:36 UTC#10
in the IGO folder
Posted Aug 05, 2009 · 13:53 UTC#11
3dcarsizemin=2500
3dcarsizemax=5000
3dcarsizemul=15000
Hi,
I also wanted to increase the size of the arrow in 2D map, can you please tell me what code, and where do I need to add to have the arrow increase in size? Thank you
Posted Aug 05, 2009 · 20:40 UTC#12
3dcarsizemin=2500
3dcarsizemax=5000
3dcarsizemul=15000
Hi,
not sure though, but i think for you to get the arrow bigger you have to enlarge the bmp and edit the the spr file.
Posted Aug 05, 2009 · 23:06 UTC#13
I thought for 2D arrow, we would add some codes like the ones for 3D arrow.... Resize the bitmap icon would be too complicated.... But thank you anyway
Posted Aug 19, 2009 · 13:41 UTC#14
So you just copy & paste this onto the end of the .sys txt and that's it? .sys is located at APL2->iGo, correct?
Posted Aug 19, 2009 · 14:09 UTC#15
put it in the [map] part of the sys.txt
