Here's the problem:
I installed an AVIC-F90BT (premiere) headunit a year ago. I performed the Pioneer Firmware upgrade to fix a few of the popular issues (bluetooth, boot-up time, nav bugs, etc.. as it has its own built-in flash drive). Everything worked perfectly afterwords, until about 3 months ago when I noticed the headunit would never remember what screen/menu it was at last when I'd turn the car back on. It remembered what source to use, but would always boot-up in the main menu instead of going to the source screen/map or where ever it was before I'd turn the car off.
I had the same issue in the AVIC-F900BT I have in another car I have. I resolved it by going into the headunit's O/S (using testmode via an SDcard), deleting all the files on the unit's flash drive and replacing them with a complete OEM file backup. Ever since then, that units worked wonderfully.
To make a long story short, I did the same thing on the AVIC-F90BT. However, something must have happened after I deleted the files on the flash-drive, because now I can't even get into the unit's O/S to put the back-up files back in. It just turns off completely just before loading up the O/S (which is windows CE).
I've looked up the issue on here and have only found 1 thread where someone has had this issue, where the person ended up sending it to Pioneer. Now, I bought it on eBay and I'm not sure of the warranty status on it. I'd really rather not go months without music in my car, hence why I'm trying to figure out if there's something I can do that I may not be informed of. I've tried going to local Pioneer distributors, but all they do is sell/install.. Not repair.
Short of sending the unit to Pioneer, is there anything I've overlooked? Is there anything I can do?
Any help would be GREATLY appreciated!!
