Making a Mono Subwoofer Pre-Amp Output
By Neil24 · Aug 03, 2009in General💬 7 posts👁️ 1,353 views
Posted Aug 03, 2009 · 18:18 UTC#1
Hi Everyone,
The AVICs use a stereo pre-amp output for the subwoofer, even though the sub is obviously just a single channel with no left or right. But I'd like to route that R & L pre-amp output through a stock remote volume knob on my car that uses a single gang potentiometer (which means the knob can only control a single channel, not both the right and left channels).
Can I splice the right and left subwoofer pre-amp outputs together to make a mono signal that I can route through the stock remote volume knob? Will doing that fry something in the pre-amp or something in my Sony XPlod Amp?
Any advice would be appreciated. Thanks.
Posted Aug 03, 2009 · 19:32 UTC#2
(A) replace the single POT with a dual POT
(B) use a set of 2male-1female Y RCA adapters off the back of the avic to go into the POT then use a 1male-2female Y RCA adapter from the POT to the amp
© just use the sub level adjustment inside the avic
(D) get an amp that has a remote bass knob(a box with a POT inside) and take it apart and put it in place of the stock POT (almost the same as option A)
Posted Aug 03, 2009 · 20:11 UTC#3
Thanks 1louds,
You've laid out the options clearly, and I was considering all of them, but I wasn't sure if Option (B) was actually feasible without damaging the pre-amp or the Sony Xlpod amp.
If Option (B) was not feasible, then I would have tried Option (A)/(D).
Thanks for letting me know that Option (B) will work. That makes the job a whole lot easier.
Posted Aug 03, 2009 · 22:45 UTC#4
yea as long as you combine the signals THEN split them back up there will be no problem with the amp and it should work great
Posted Aug 07, 2009 · 15:37 UTC#5
i would just check it, sometimes if you try to combine two signals they cut eachother out somewhat. hook it up, then see how much the sound changes by unplugging one of the wires from the avic to the bass pot. it should get quieter, but see if it changes much. with speakers it often does.
Posted Sep 30, 2009 · 15:29 UTC#6
Hi all,
I finally got around to my install, so I thought I should report back.
Option B worked just fine, and I was able to use the car's stock volume knob as a bass level control for my sub. A total success!
Thanks for the advice everyone!!
Posted Sep 30, 2009 · 17:04 UTC#7
sweetness
