I just completed a bypass of my D1 unit by using the A-Ant lead and moving it over then grounding it. The bypass worked perfect, however, my FM reception is no longer as good as it was and I get no AM reception at all. I was assuming that the lead was for a "automatic antenna" Do 4runners use the wire to for some sort of amplified antenna? Thanks.
Posted Nov 08, 2006 · 01:54 UTC#1
