Tilt Increments?
By 69sixpackbee · Aug 04, 2009in Hacks/Mods💬 6 posts👁️ 1,176 views
Posted Aug 04, 2009 · 20:34 UTC#1
I have been scouring through what code I can and I am trying to see what controls the AMOUNT of tilt incrementally. For instance, when I push the up or down arrow of the tilt/zoom popup it does not tilt in small enough increments. I can get ALOT of horizon or none at all when I am trying to set my tilt level. I **Don't think** it is in the sys.txt. Here is a copy of the one I am currently using in my F90BT(V3.01 now):
[device]
type="PIONEER746UC"
[interface]
skin="ui_pioneer"
default_day_color="COLORSCHEME~Pioneer Blue Day"
default_night_color="COLORSCHEME~Pioneer Blue Night"
tmc_events_icon_set="$tmc2.spr"
small_tmc_events_icon_set="$smalltmc2.spr"
show_kml_type=0
mapfontscale=200
maxzoom2d=6000000
show_exit=1
defaulttilt3d=8300
[rawdisplay]
screen_x=800
screen_y=480
class="landscape"
highres=0
dpi=250
[debug]
speedcam_enabled=1
skip_eula=1
show_speed_limit=1
enable_roadshadow=1
enable_buildings=1
restart_mode_in_file=1
traincrossing=1
show_lane_info=1
[folders]
data="\My Flash Disk\User\UserData\iGo"
tts_nuance="\My Flash Disk\APL2\iGo\ScanSoft\RealSpeakSolo"
secondary_app="Storage Card/usericon,USB Disk/usericon"
usb_trackexport_path="\USB Disk"
storage_trackexport_path="\Storage Card"
[gps]
port=7
baud=9600
default_latitude="34.05116"
default_longitude="-118.24258"
[3d_config]
roadsign_lines_per_screen=19
[local]
voice_key="Eng_us_m1"
default_language="english US"
[regional]
units=1
[dynamiccompressor]
compressor="1"
a0="56806"
thrs="24703"
ratio="8"
gain="8"
[timezone]
reset_os_timezone=1
multi_timezone=1
[map]
2dheadup=1
zoomfactor=110
3d_scale_carmodel=1
3dcarsizemin=4000
3dcarsizemax=6000
3dcarsizemul=35000
3d_tunnels=1
3d_max_tiltlevel=10000
3d_max_zoomlevel=3000
3d_min_zoomlevel=40
3d_max_zfar=8000
show_oneway=1
[smartzoom]
minangle=30
maxangle=81
;restore_smartzoom_on=1
Thanx for the help :)
Bud
Posted Aug 05, 2009 · 13:34 UTC#2
It is in your pioneer.ini file.
[map]
3d_scale_carmodel=1
3dcarsizemin=3000
3dcarsizemax=3000
3dcarsizemul=40000
building_render_distance_far_front=6.0
building_render_distance_far_back=3.0
building_render_distance_medium_front=3.0
building_render_distance_medium_back=2.0
building_render_distance_near_front=2.0
building_render_distance_near_back=2.0
3d_max_tiltlevel=7400
3d_max_zoomlevel=500
Posted Aug 05, 2009 · 15:04 UTC#3
But which one??
Thanx,
Bud
Posted Aug 05, 2009 · 15:09 UTC#4
Posted Aug 05, 2009 · 15:37 UTC#5
That just sets how far of the horizon, if you will, will show up. No?
In my Sys.txt file (which overrides the pioneer.ini settings[?]) I have played with that setting which is now at 8800 if I want to see more sky and then it defaults back to the 8100 I have set by the press of the "MAP" button or at reboot. This does nothing for the increments of the screen tilt which are usually pretty drastic from one press of the tilt "button" to the next. I am wanting to fine tune the amount of tilt per button press so that it is not as drastic of a change.
Thanx<
Bud
Posted Aug 05, 2009 · 15:52 UTC#6
Oh now I understand I would like to know this as well.
