AVIC F900BT firmware 2.006 update
By TWoods450 · Aug 05, 2009in Problems/Troubleshooting💬 8 posts👁️ 2,244 views
Posted Aug 05, 2009 · 04:01 UTC#1
I started the update 16minutes ago, it now estimates remaining time to be over 6 hours... please tell me this is not normal...
Posted Aug 05, 2009 · 04:16 UTC#2
Not normal. I did it yesterday. It took 15-20 mins total
Posted Aug 05, 2009 · 04:42 UTC#3
whooo, went out 15 min later and it was going faster, took about 40minutes.
Posted Aug 07, 2009 · 01:14 UTC#4
OK... tearing my hair out.
Have an F700BT that I'm trying to update the firmware on from 2.00000 to 2.006. Each time it boots from the SD card and states (with a bright red background mind you) that the LPUE080/APL/AVRES.RES file is wrong.
I have the 2.006 firmware from Pioneer's site 4 times now and can't seem to figure out what I'm doing wrong. Both folders are where they are supposed to be on the SD card, it's formatted the correct way... Any ideas would be greatly appreciated...
Cheers
-Gunny
Posted Aug 07, 2009 · 12:22 UTC#5
Gunslinger, for some reason the avres.res file is corrupt to the point it won't pass the check the system does on upgrade. Try downloading that one file to the SD card again from the PC. If worse comes to worst, I can email you the file from my unit this evening, taking for granted that the file is small enough to email.
Posted Aug 07, 2009 · 14:32 UTC#6
Thanks gsxr...
I've tried wiping the SD card multiple times, reformatting it (FAT16), redownloading just that file and also redownloading the whole zip file from Pioneers website to no avail. ):
this is the link i've been using to get the files...
http://ds1.downloadtech.net/cn1010/firm ... 006000.zip
maybe it's the wrong one?
but... if you could email it to me (it's 168K), i'd appreciate it. [email protected] (obviously remove the _NOSPAM_)
THANKS!!
-Gunny
Posted Aug 07, 2009 · 17:50 UTC#7
Since it's small enough to email, I'll bust it out to you when I get home. You should have the file around 5pm.
Posted Aug 08, 2009 · 13:42 UTC#8
no mail yet.... (:
