Power drainage
By djoker04 · Nov 08, 2006in Off-Topic💬 3 posts👁️ 1,515 views
Posted Nov 08, 2006 · 11:53 UTC#1
I have 4 monitors in my armada and Have 3 AND the DVD player going to the Fuse box via a dual in-line fuse holder. My Q? is should i use a the proper Fuse AMP for the slot (10) and use a lower for the other or go higher. When Connected it's causing a Batt drain. My other opt is to connect them to a switch and turn it off when I get it out. Thanks in advance
Karl
Posted Nov 08, 2006 · 14:22 UTC#2
Are they hookes up to a constant power feed? If so then move them over to an igniton controlled feed this way they'll turn off when you shut the truck off.
Posted Nov 09, 2006 · 03:25 UTC#3
Yes. I have it like that so that the dvd won't turn off if i stop and have to restart and find the last point of view. What I might do is remove the monitors from that line and place them on ignition conrol and have the dvd on Constant Pwr. I just might go back to my other dvd I had that maintained memory when I turned it off.
Thanks AW.
K
