Nav Voice Mute Button
By nbdew002 · Aug 05, 2009in Hacks/Mods💬 4 posts👁️ 1,689 views
Posted Aug 05, 2009 · 18:58 UTC#1
If you have figured out a code for the new 3.01 can you please share it? I like the stock maps but just want just want to add a voice mute button.
Thanks in advance.
Posted Aug 05, 2009 · 19:03 UTC#2
Thanks in advance.
This is what is in Keepers mods:
;Voice guidance mute
;Stop Nav Button
You will probably also have to go and dig out the bmp's that are listed and put them into your data.zip in the same location as well. You are going to also have to toy around with the position.
Posted Aug 05, 2009 · 19:31 UTC#3
Thanks in advance.
;Stop Nav Button
Where do I insert this code?
Posted Aug 05, 2009 · 19:59 UTC#4
Extract the data.zip and then put it into the navigatemap_800_480.ui file in the ui_pioneer/800_480/ui folder. It goes into the section.
