turning-off internal amp?
By smarsh · Nov 08, 2006in General💬 16 posts👁️ 5,688 views
Posted Nov 08, 2006 · 16:18 UTC#1
Hi,
i just added a new 4 channel Alpine Digital Amp to the Z1..... any way to turn-off the internal amp?
For a VERY $$$$ system, the Z1 sure lacks in adjustability!
Sam
Posted Nov 08, 2006 · 22:48 UTC#2
I think you need to use the RCA preouts on the wire harness. That bypasses the internal amp.
Posted Nov 08, 2006 · 23:33 UTC#3
There is no way to disable the internal amp on the z1 or any of the avics for that matter.
Posted Nov 08, 2006 · 23:44 UTC#4
Are you sure?
I always though that those RCA pre-outs bypassed the internal amp? If they don't, then what are they there for?
Posted Nov 08, 2006 · 23:53 UTC#5
rca's are "pre-outs" meaning its pre amp, meaning you arent going through the decks amp..... There is no need to "disable" the amp, if you arent using the speaker level which is the amp'd signal then you dont need to worry about the amp at all
Posted Nov 09, 2006 · 05:15 UTC#6
Ok.
IS there a huge difference between high level and low level inputs?
I don't know for sure yet, but I just bought new RCA harness for my N1. Hoping it'll cure the malfunction I'm having. So, would it be okay to run my Zapco amps on high level inputs?
TIA.
Posted Nov 09, 2006 · 05:26 UTC#7
you would want to use the rca's they are theoretically cleaner.... the amp in the head unit is really not the best, I mean, contained in the head unit it is also a 50X4 watt amp, compare that to your 50X4 zapco or whatever amp.
Posted Nov 09, 2006 · 06:12 UTC#8
Don't high level your Zapco. For a high-end amp like that, go out and buy some decent or better RCA cables and it will sound FAR better than the high level route
Posted Nov 09, 2006 · 07:46 UTC#9
I may have "toasted" my preouts while doing the N1 bypass. So, I'm not sure if it'll be possible to use them anymore.
You're absolutely right. I'm running medium grade RCA cables, that I bought from Circuit City. Eventually when the time comes, I'll run a Symbilink Balanced Line Transmitter. I've heard it's susposed to make a world of a difference. Especially with my ads components.
I'll find out Friday, and will let you guys know.
Posted Nov 09, 2006 · 18:05 UTC#10
yes, the line-outs bypass the internal amp..... but, on *most* head units i have had you have the ability to simply turn-off the internal amp... not simply bypass it...... granted, having no load on the lines out of the internal amp effectively causes it to suck little juice.... i would still prefer to turn it off all together to reduce heat (and sucking electrons too!)
Sam
Posted Nov 09, 2006 · 19:13 UTC#11
Using the preouts on Pioneer decks does not bypass the speaker-level outputs, they are still active all the time. That being said, if you just tape them off, they will pull barely any power from your system
Posted Nov 09, 2006 · 20:05 UTC#12
Sorry I dont know of any decks that you can turn the speaker level outs off on.
Posted Nov 09, 2006 · 23:12 UTC#13
In the Pioneer line, I know you can turn the amp off on the Premier DEHP880PRS. Other brands do it too on the high sound quality models
Posted Nov 09, 2006 · 23:18 UTC#14
wow thats neat. wounder if it really translates into performance improvement
Posted Nov 11, 2006 · 02:36 UTC#15
it'll technically reduce electrical interference. Probably nothing that you would be able to hear with the human ear.
Posted Nov 11, 2006 · 02:39 UTC#16
Higher end alpines and some kenwoods have the option to turn offf the amp ic. I know my alpine 9855 does. As far as sq improvement goes, I didn't notice any change. Then again for as noisy as a car is I doubt anyone would notice if there was an improvement.
