3.0 Text Syntax Help - navigate 800 ui file.
By bsnively · Aug 07, 2009in Hacks/Mods💬 6 posts👁️ 811 views
Posted Aug 07, 2009 · 18:07 UTC#1
For some reason my text isn't showing up on the screen. The button and variables show up, but not the label saying what the data represents.
Does anybody notice anything wrong with this - or have anything that they could suggest trying.
Thank you,
Ben
Posted Aug 07, 2009 · 18:15 UTC#2
Thank you,
Ben
Are you sure you need formatmodel there? I believe it is only applicable to date/time/numeric values, so when you are trying to apply it ti a straight text, iGO tries to convert "AVG SPEED" to a numeric value, obviously fails, and gives you a blank string...
Posted Aug 07, 2009 · 18:36 UTC#3
That may be it. I'll try it this afternoon and let you know.
Thanks.
Ben
Posted Aug 07, 2009 · 20:39 UTC#4
Yup -that was it.
THANK! - updated data.zip I was working on (which was really stuff from others) and posted on other thread.
Ben
Posted Aug 07, 2009 · 21:33 UTC#5
Yup -that was it.
Ben
Good :)
Posted Aug 07, 2009 · 21:53 UTC#6
Yup -that was it.
Ben
Good :)
Double good! :):)
Wonder why it worked in the other versions. I've been running these since late December with the same coding.
