AVIC Z100BT INSTALLATION PICS!! 2008 CHEVY AVALANCHE
By Kingdaddy · Aug 08, 2009in General💬 14 posts👁️ 12,501 views
Posted Aug 08, 2009 · 12:52 UTC#1
Here we go - I just replaced the factory BOSE navigation system in my new 2008 Chevy Avalanche LTZ. Here's a run down of the system with the pricing I paid and where I purchased it:
Head Unit: ZVIC Z100BT - Amazon, $1329 (Discount Jungle)
Amplifier: JL Audio HD600 / 4 - eBay, new, $511.24 (Seller is audio-club)
Front door 6.5" speakers and tweeter: Jl Audio VR650-CSi Car Component System - eBay $129
Rear door 5-1/4" speakers: Alpine SPR-13C Coaxial 2-way speakers - Discount Auto Sound (Newport News, VA), $149 installed
1 Pioneer CD-IU50V USB iPod - Amazon, $42.81
Pioneer GEX-P920XM XM Satellite Tuner - Amazon, $88.78
GMOS-LAN-02 LAN OnStar Interface for Amplified Systems - Amazon, $96.68
PIONEER GEX-P20HD - HD TUNER - Amazon, $91.41
I followed the instructions for the Z100BT bypass, and it works great! Just follow the instructions on a YouTube post if you want video (search for AVIC Z110BT bypass). There are also written instructions in this forum.
NOTE: The AM FM buttons are disabled when you install HD Radio, you simply change bands within the HD tuner! So don't think there is a problem when they don't light up after connecting the HD tuner.
Also, be sure to note the crossover placement if you have a similar GM vehicle and you are installling component speakers.
Okay, now here are the pics! I hope you find this helpful!!!!
BTW - I've reached my limit (10) on attachments, so I'll add a couple more in a reply.
Posted Aug 08, 2009 · 13:03 UTC#2
Here are a few more photos.
BTW - we used 4gauge Monster wire to wire the JL Audio amplifier.
Discount Auto Sound in Newport News, VA completed the install, and did a great job. Thanks guys!
Posted Aug 08, 2009 · 19:29 UTC#3
now thats what i am talking about!!!! nice job
Posted Aug 08, 2009 · 21:54 UTC#4
AVIC Z100BT Bypass in operation one day after installation. Works great!
Just move the yellow wire one slot over, and ground with the green wire as shown elsewhere on Youtube.
This unit is simply incredible. Enjoy!!!
Posted Aug 08, 2009 · 23:07 UTC#5
AVIC Z110BT Operation pics!
Note the customized splash screen - you can do this when you install an SD card. I bought a 16GB class 6 card off of Amazon for about $50.
Awesome!
Posted Aug 11, 2009 · 17:35 UTC#6
Did you hook this up to your remote start? I have an 08 Avalanche and was able to hook the acc up to a power input that was activated with the remote start and kept power the whole time the car is running. I did my install about 8 months ago and haven't had any problems. The wire is a grey one in the fuse panel of the passenger side. The only down side is you can't keep the retained power and the remote start, or at least I couldn't figure it out.
Posted Aug 12, 2009 · 13:21 UTC#7
No, remote start was not hooked up. Don't really use it anyhow, in my opinion, it's best used in cold climates, and when it does get cold around here, I"m parked in the garage, so I don't really need it. However, I would have kept it enabled if I knew how.
Posted Aug 17, 2009 · 00:00 UTC#8
nice! should have mine in week, :D
Posted Aug 29, 2009 · 17:11 UTC#9
After you used the GMOS-LAN-02 LAN OnStar Interface for Amplified Systems connector were u able to keep onstar and door chimes like factory? I have a 2007 gmc sierra crew cab with rear audio controls, onstar and steering wheel controls and boss factory radio and have an avicz100bt comin in on sept 9 i would like to keep factory speakers in and just add amp and subs so im trying to find the right conversion cable to hook up to the pioneer and find out if the amp on the factory boss is in the radio are hidden under dash for rest of speakers? Any Ideas..
Chad
Posted Sep 06, 2009 · 20:37 UTC#10
I was able to keep the door chimes.
However, I did not keep the factory speakers or amp. I am told the amp is under the passenger seat, but I haven't checked.
Posted Apr 16, 2010 · 20:32 UTC#11
I just completed the install on my 2007 Chevy Tahoe, had to cut some plastic from the bracket that held in the factory radio. The spacing is tight behind the navi but after cutting it barely made it in. I used the GMOS-LAN-02 LAN and retained all factory chimes and onstar. Only thing I lost was the rear entertainment control.
I just read that the PAC OS-4 supports rear entertainment control, too late now everything is in!
Posted Apr 17, 2010 · 11:08 UTC#12
Congrats! Hope you enjoy it. As for OnStar, I could care less about that - too expensive for what you get.
Have a great weekend!
Posted Apr 17, 2010 · 13:07 UTC#13
Excellent pictures of your z110 going into your avalanche ... i'm surpised you wanted to remove the Bose speakers and throw in jbl's. do you find that there is even a more "richer" sound from the jbl's vs. bose? I' have bose speakers in my truck and noticed after my z110bt was installed, the sound quality significantly improved
Also - here is a question for you ...You know how on your dash where you can turn on/off your air and heat? I would assume that the 08 truck illuminates these buttons when your headlights go on? did any of the illumination buttons on the display panel stop working after you installed your z110? Reason I ask is because I have an 05 gmc yukon SLT and when i had my factory unit removed and the z110 installed, 3 of the buttons that control the heat/air, etc. don't light up anymore. I had the same problem with my last GMC truck which was an '04 yukon and i thought it had something to do with the electrical system in my last truck but now i'm thinking it may be something in the way the z110bt is wired.
Posted Apr 17, 2010 · 18:20 UTC#14
Thanks.
I added the amp, and apparently couldn't run the stock Bose speakers with it. BTW - I'm not running JBL speakers, they are JL Audio and Alpines.
Funny, the guys at the car stereo shop that helped had a saying "No highs, no lows.....must be Bose".
I have had no change in dash illumination after installation, so I don't know what might be up with your system. Perhaps someone else in the forum knows?
Also, I just bought an iPad, would love to have that hooked up in the dash! Someone has already done that for a car, check out the video on YouTube:
