🔒 Locked
How to bypass question
By Grxmites · Aug 09, 2009in Hacks/Mods💬 8 posts👁️ 4,281 views
Posted Aug 09, 2009 · 22:44 UTC#1
Hello:
This is my first indash unit. I noticed alot of poeple talking about bypass but i barely see instructions on the X series board. Can someone post instructions maybe with some pics for noobs like me.
JON
Posted Aug 10, 2009 · 00:17 UTC#2
Same as F series
Posted Aug 10, 2009 · 16:51 UTC#3
is there a tutorial for it, im super lost when they say ground the cables.
Posted Aug 12, 2009 · 20:22 UTC#4
please dont take this the wrong way but if you dont know what "grounding" the wires means then you shouldn't be messing with the install at all, and i would get someone that knows what is going on to help you before you turn the unit or your car to toast
every car (modern cars) uses a negitive ground system where the negitive terminal of the battery is directly connected the the body(metal of the car), Every electrical component in the car gets its power from a cable(or wire) that is connected to the positive terminal of the battery (and routed through a fuse box or fuse) and since the electrons need to travel in a complete circuit, every component then connects to ground (the body of the car, not the dirt outside) where the electrons can travel through the metal in the body to complete the path to the battery.
Posted Aug 16, 2009 · 20:47 UTC#5
I just did the bypass on my X710bt. When I first start the system up a caution screen still comes on when you go into map mode or when you answer a call via bluetooth before going into map mode. How do I get rid of the caution/disclaimer? I've done the 3.00100 upgrade.
Posted Aug 17, 2009 · 14:36 UTC#6
had you tried the search feature, you could have found out for yourself
anyway, here comes the baby spoon, veeerrrrroooooooooommmm
many have tried,and until very recently no one has been able to do it, there is a thread where some one found out which files to modify
Posted Aug 18, 2009 · 04:01 UTC#7
disreguard this thread, i did it.
THANKS
Posted Jan 22, 2010 · 17:32 UTC#8
Attached is a doc explaining how to do a software bypass.
AVIC Software Speed Bypass.doc
