vss for a 2000 lincoln ls
By redrider25 · Nov 08, 2006in Vehicle Specific Wiring💬 8 posts👁️ 2,007 views
Posted Nov 08, 2006 · 23:33 UTC#1
wheres the vss? also is there somewhere i can connect the reverse gear signal to? thnx
Posted Nov 08, 2006 · 23:52 UTC#2
Don't have access to my tech stuff right now, but try his for vss. In one of the harnesses behind the radio, there should be a gray/black wire. That should be your vss. It won't be in the same harness where you're speaker wires and power connectors are. It should be in the large cube looking plug. as for reverse I can't really say at the moment.
Posted Nov 09, 2006 · 00:21 UTC#3
i see 2 grey and black wires
Posted Nov 09, 2006 · 00:21 UTC#4
o and no need for the reverse signal
Posted Nov 09, 2006 · 00:22 UTC#5
One of those is going to be a speaker wire and the other will be your vss then. Like I said the one in the cube looking harness will be vss and the one in the harness with the power wires is going to be a speaker lead.
Posted Nov 09, 2006 · 00:26 UTC#6
i have 3 diff harness cubes both of the grey/black wires are on the same block
Posted Nov 09, 2006 · 00:34 UTC#7
Well then the only thing I can say is to grab a multi meter and test them.
Posted Nov 09, 2006 · 01:06 UTC#8
scared ud say that but thnx for the info and time
