I've run into some trouble installing F700BT in my 2002 Saab 9-3 Viggen Convertible.
My car interfaces with the OEM radio's dimmer through a digital connection, so I had to tap into a dashboard light. I tapped into a light around my cigarette lighter, and I'm not seeing any dimming in the avic.
I tested the dimmer/illumination pin on the harness that plugs into the AVIC and found it was getting the power... 2V at lowest dim and about 11V at highest.
I'm wondering what is normal. My car can't have its headlights shut off so if the unit really only has a lights-on/lights-off mode, maybe I shouldn't expect to see anything. But if I should be seeing a smooth range of brightness as I adjust the dimmer, I guess something must be wrong.
How is the dimmer supposed to behave? Smooth adjustment or just "lights-on"/"lights-off?"
