Hey Guys-
Lets talk layers. I am trying to add an icon/menu to keepers drop down menu. The icon will show up at the bottom below the MSN icon as I placed it. This is the code I used at the bottom of Keepers menu to get it to show:
To add in a layer (that you would tap to get the slide menu to come out so you can have an action) I created/added in this layer at the bottom below the layer:
If I leave this code commented out the unit starts fine. The icon will show up at the bottom below the MSN icon as I placed it. The problem is when I push the icon to expand the menu I get an error. The error that I am getting is:
FFUIERROR: Unknown object identifier
Identifier=[ui_QuickMenuButtonTrip]
Script "[unnamed]" command 0
I figure its because I need the layer above that I tried to add. Problem is when I add it I get system starting message. So my question is what is the trick to adding layers that I am missing? Do I need to define something (script?) somewhere else?
Thanks,
Alex
For reference here is keepers link:
